I had several goals here not the least of which is to sell trains. In each case, I want to represent the strong points of each scale.
O scale: The details. Although I have a loop, I’m going to recommend this one not run and just sit at the station. At best it will chase it’s tail and look weird.
N scale: Long trains, big scenery, small space. Here I will recommend what we see here, a double-headed coal drag with 20 cars. And PA oak forests are easy to make.
HO: Sound and details
Obviously the HO is set-up for switching and will give the customers supervised hands-on experience with something besides roundy rounders and have a good sounding loco like a PK2 0-6-0 or a BLI SW7. I’m looking to decorate the switching layout with some of those stylized mid-range priced high detail kits like Bar Mills, etc. to give the full impact of model railroading. A wood trestle is the end of the HO track on the right spanning both the N and O scale tracks.
The O and N will be separated by a 6" retaining wall and a 1" planted grade. N and HO will be separated by a rock face and 3" of N scale trees.
depending on the overall height of the layout, maybe consider doing scenery on the entire N and O section but have the HO switching section mounted on plexiglass supported by a series of concrete or stone peirs (which ever best fits into the era/scenery below/time and money budgets.)
Thinking the little ones would be able to see up thru the plexi, the taller customers would be exposed to the entire “below grade” scene INCLUDING the unseen workings of a switch machine in action.
Granted, the HO portion would be more detail exposed but this may be worth considering.
I think we are to accept that Mouse has been given, and has in turn accepted the challenge for, terms of reference that are cast in concrete. It’s gotta be a 4X8, and that is about his suggested design about which he would like feedback. Why not turn our creative thinking to the confines he has been given?
Chip, would it be useful to remind us of the parameters? Some folks looking into this discussion may not have seen your other introduction.
As I said elsewhere, I like what you have done. Simple, effective. I am intrigued by the plexiglass clear middle idea…has some merit, particularly if this is meant to be an educational tool in addition to a mere display or eye-catcher.
One possible answer for the O gauge loop. Hide more of it - enough to stage a train. Then put TWO trains on the loop, with a circuit that will start the staged train as the other leaves the station and enters the tunnel. The train coming out of staging will stop at the station. You might arrange a “push to start” button so the audience can control the action.
You might run an N scale train that’s almost as long as the loop it’s on, except for the front ‘straightaway.’ At prototype 40=-mph, it would seem to take forever to pass through the scene.
I like the HO having the most detail and the best spot - but then, I’m biased.
I’m not too sure about the Lexan surface idea. It’s a really tricky material to work with, except for the one use you might really need to consider. A transparent screen would help to keep miniature 0-5-0s from making unauthorized ‘adjustments.’
You might want to make the N-scale loop less symetrical. The only “concern” I would have is people might see how cool the N-scale trains look, but then they get there set home and it doesn’t look as cool on 9 3/4" curves that came with the set.
Are you going to have a shuffle circuit for the HO to have action, or are is the HO going to be static?
Well part of the reason for the layouts is to show people the difference between toy trains and model railroads. They’ll just have to buy some flex. The people won’t be able to see both sides. The layout is in an aisle (the product part) with both ends blocked.
I’m not sure what you are asking about the HO. It is going to be DCC w/ sound. Won’t move unless the customer is playing with it.
Chip is there anyway you could add a 18" and a 24" radius to the two tracks on the left side over the tunnels? If they could have a long enought arc then people could see the problems of trying to run a Big Boy or long cars on a 18" radius. It might make it easier to explain about the overhang and the operating limits of longer equipment.
I suspect that the LHS owner will mostly want to run this in continuous-running mode, because he’s not going to be able to spare someone to actually operate a switching layout. Sure, it’s nice to see that sort of thing, but as a practical matter I would have the sound-equipped HO engines running all the time, even if it’s only a loop, because they will be the biggest attraction. O-gauge should be running, too, not just static. It’s the motion that will attract attention, not the modelling.
I just meant some sort of back and forth automatic running circuit.
Ah, what measures are being taken to prevent the trains from running off the edges? I am certain customers will do that (by accident or intentionally) as well as onto the ground at the end of sidings, and derailed through the turnouts set incorrectly. Is this whole thing going to be encased in plexiglass?
The Old Dog gets the feeling that Chip might be wise to go back to the requirements definition stage.
As stated immmediately, the LHS is going to need something that can be turned on in the morning, run all day with little attention, then turned off at night. That would probably imply a set of ovals to keep things moving.
Given it’s small size, N-Scale might be hard for people to view at any distance. It might be better displayed as a “foot locker” layout in a display case.
Also, should the layout include tinplate as well as scale O-Scale? Could some G-Scale be worked in? Any traction? Street cars can run back a forth while looking normal. What about Bachmann On30?
Is that scale or tinplate O? In any case I do think it should run, even if the train has to be short, maybe even a small switcher and 2 cars, to minimize tail-chasing. I dunno about what people in general want to see, but I know what I like.
I really like the notion of giving people the ability to switch the HO. The track would have to be cleaned regularly, since you’re not going around and polishing it constantly, and it goes without saying that everything would need to be carefully done, but I think it would be worth it, if people who are starting to get bored with just running trains find out for themselves how much fun switching can be.
HO is a good compromise for the switching layout. It’s heavier and bigger than N, which should ease maintenance. Switching with O might be better yet, but I don’t know if it’s scale O, and anyway it would take up a lot of space.
I do think that the HO should have a continuous run of some sort along with the switching. What if the plan shown was extended and bent into an oval somehow, then offset with the O and N levels? That would also give some room, perhaps, for a spur off the N or O line, which could make them look a bit more “important”.
To come from left field a bit, what about some interaction between the three lines? This could be a little odd (what scale would the structures be?) but it could also be interesting. They could bridge over each other, for instance, which would probably look better if the smaller scale was on the bridge.
[2c] I think it will promote HO over N and O scale, because that is the one that is " hands on ", and the others are not.
I’m not blaming you or accusing you of promoting one scale over another I am just very doubtful that a 4x8 will be able to give all 3 scales equal billing no matter what is done, unless you have 3 levels each of which is 4x8, to fully show the strengths of each scale - this can be done with O scale in this much room, this is how much room it takes for HO to do the same thing and this is how much room it takes N scale to do the same thing as HO and O.
AP, It is what ever three rail Lionel is currently selling.
Greg,
Although you are problably right, the idea is to change the perception of toy trains to model railroading. Right now the owner has a toy train mentaility. It’s for him as much as the customers.
If you are building the owner a toy, looks fun. But, a huge part of his profit will come from HO locos, and the buyers will want to see them run, something this layout does not display.
This project is not a work of art reproducing the real world in miniature, or an operational superpower. It is a sales tool. So if anyone has a problem with SALES, well stop buying stuff!
