Hogwarts loco, passenger cars
Hello, I recently aquired a brand new Hogwarts set. The loco produces very little smoke. I followed instructions, four drops of fluid. Put a load behind of it too. Is this fixable. And another thing. Instructions for replcing lights in the passeenger cars are vague at best. I think I would need three or four hands to remove the car top if I could figure out which windows to press. Help. Thanks. bossman
I don’t own a Hogwarts set, but the smoke subject’s come up before. The consensus is the Hogwarts engine is an anemic smoker, on a scale of one to ten it’s usually three. I’ve got a Lionel Strasburg 0-8-0 that’s the same way, it smokes a bit better with a heavier load on it, say six or more cars. Nothing I can do about it, it’s the nature of the beast.
Lamp replacement on the cars? That I don’t know about, maybe someone else can tell you.
Four drops is not enough. I put half a dropper in.
If you look really close to the doorways you will see the dimples that you need to press for removing the roof. Mine is of the first issue and it smokes just fine.
pressing with a pop sickle stick helps save the fingers
Try 8 drops…
Roofs are a pain. Best way is to squeeze the 4 windows in and actually twist the car a little with both hands like your ringing out a towel…
Thanks for the info. Maybe I’ll try more car ans more smoke fluid.
Thanks for the info. I will try all your suggestions.
I know pain. I will try popsicle sticks and the twist. Thanks for the help.
One other thing. My set came with 0-36 fastrack but that was too tight for my engine and the pilot wheels ground into the cylinders. I had it looked at by a Lionel repair guy but he said it was adjusted properly. So, I bought 0-48 fastrack and run it on that.
Mine is agreat smoker like a cheap cigar. I noticed on all my Lionchief engines that the bluetooth app produces more smoke that the hand held remote factory setting, for whatever reason. On Lionchief set that are non bluetooth if I want smoke and lots of it I start the track up at 22volts z4000, that does it.
I also started last year using a smoke fluid from PATS train shop and its great, his daughter developed it, you might look into it.
