home made tree looking for opions
Hi heres a pic the green tree i made out of christmas tree garland … how does it look? is it to scale ? you can see the box car and 2 pro made H O trees for comparing…
thanks all hobojim
Looks better than the red and yellow one
BUT: I would make the trunk area more obvious. The branches going stright done look funny. AND I would put some static grass on the tips to simulate needles. If you are after deciduous, then the tree is too ful and it will need leaf foam or leaf material to simulate leaves.
Its a good start, maybe the best you have done, but maybe not the best you will ever do. Practice does improve one’s tree making.
Try hitting it with some spray glue and grass or ground foam.
Like loather said glue and ground foam an I would trim the top so it doesn’t lean over…but its a good start…Cox 47
That is good advice. Mosty trees aren’t fully symmetrical, so you may improve its overall appearance by taking small scissors and snipping out chunks of the tufting here and there. Then spray glue and sprinkle with a medium dark ground foam. Spray again and cover the first layer with a lighter, maybe finer, ground foam to simulate new growth. Try it on one, anway, and see if it works for you.
