In my opinion, for what you’re doing I suspect ‘cheaper is better’ – you’d want the soft, flexible glue, and that’s usually the low-temperature kind. Harder glue might might start to rip the face off the cardboard when you load it.
For the kind of work I think you’re proposing, a more important gun feature will be effective ease in loading sticks and dispensing, including ‘pullback’ without dribbling.
Cost of the sticks is also important. In my experience both small-diameter and large-diameter sticks come at a premium price.
If you have, or are considering, other crafts that use the higher temperature glue, then a dual-temp model may be worthwhile.
Take careful pictures as you work (including of any ‘missteps’ you might make on the way) and document them here.
AFAIK there was only one temp glue in the 80’s when I used this technique, high temp. You can use elmers glue, but that takes too long to dry and you run out of clothes pins
You aren’t going to rip the cardboard with less flexible glue because there are no sheer forces.
You want to use low temp with foam, but you are not doing that technique.
As Overmod points out, the worst part of using a cheap gun like I have is that the glue runs off whenever I set the gun down. I have to be very careful where I work and where I lay the gun or I will have glue all over the place.
My own experience is that I had better results using a stapler to fasten the cardboard strips to wood and the hot glue gun for fastening the cardboard strips to each other.
Low temperature hot glue works for all the materials we use. You get plenty of adhesive strength from low temperature hot glue.
The hardshell is going to take the loads, you could probably just use masking tape to hold the cardboard while you put the plaster cloth in place (or whatever you intend to use for your hardshell).
Woodland Scenics recommends using wadded up balls of newspaper to support the shape of the hardshell rather than the cardboard matrix you plan to use.
After I read the book of Howard Zane about his HO layout, I use hot glue, staples and masking tape to glue the carboard strips but also the hardshell because I use Red Rosin Paper hardshell and no more for ever, plaster .
I have never take a look of the kind of glue I use, don’t know if this glue is the hot one stuff of the low temp one, it’s just a Pattex brand I find in hardware store.
The only drawback I have and I have used other stuff of hot glue, is the small “wire” glue which are a bit invasiv.
When my hardshell and the Rosin paper is glued I paint the whole stuff with full strong white glue with a brush; the glue is mixed with green or brown latex paint to definitively hide the red color of the paper
Scenery materials comes after as usual.
Quick, neat, no dust, really a dream in a railroald area.
What are you securing to cardboard to for subroadbed? I can speak to using foam and found that an inepensive glue gun works. There’s no need to go crazy on getting an expensive gun. I got mine and a package of glue sticks from Michaels.
I didn’t know there were different types of glue sticks. I just buy whatever I find at Walmart and set my glue gun hi/lo setting to high.
I went a little nutty on my last layout - sort of “raster scanning” the landforms with cardboard strips. It seemed to work well so I am planning to use a similar technique on the next one.
I used this method on an expansion section (20x25’) to the existing layout. I used hot glue to attach the cardboard strips, but I added staples to give it a stronger bond. Be careful when stapling if the glue is still hot (don’t ask me how I know). Better yet, wear some leather work gloves.
I didn’t make the cardboard strips uniform when I attached them together. This aids in having rolling scenery. I then covered the area with plaster cloth. To cut down on the mess, instead of dipping the plaster cloth in water, I cut it to shape, then thoroughly wet it with a wide paint brust.
I found applying the plaster gauz to have very little mess. I did cut the gauz into squares about 7 or 8 inches wide and used a roller paint pan to dip them in water and the drape allowing some water to drip into the pan first. There was a few drips of water but no big deal.
I tend to model flatter scenery with hills that I can make from crumpled up newspaper under plaster covered paper towels. Haven’t had to do the land form thing.
Just curious, how long does it take to cut up all of those cardboard strips, and what do you use to cut them so precisely?
To wet plaster cloth without soaking it Woodland Scenics points out that you can apply it dry and then use a spray bottle to wet it down with water. That works well.
