How best to color cast /plaster buildings.
Does anyone have a water base technique rather than the Floquil oil method. I was think along the lines of a primer /sealer then painting. But I am open to new ideas. Thanks in advance for the advise. David
I personally don’t like to seal plaster before painting. I use thinned down water based craft paint. It seeps into the plaster and give it a nice, realistic look. If you seal it first, the paint will just sit on top of the primer and look more like painted plastic.[2c]
Go to <Railroad Line Forums\Forums\The Craftsman’s Corner\Seal or no seal test> for the current discussion on this subject. I always seal with a light coat of Rustoleum gray in a rattle can. This becomes the morter lines for a brick wall.
Having built a few of Randy’s Downtown Deco kits, I follow his advice and lightly overspray the casting with either a clear finish or a white paint from a rattle can. You don’t want to completely coat the castings, just a light overspray. The water based paints will still soak in, but you will have a bit of working time.
Drew
