How big is your layout?
After looking at some weekend photo fun photos, I started to think about scenes people were taking pictures of. It Made me wonder how big everyone‘s layout is. Do a lot of people have giant room sized layouts? Or smaller 4x8 layouts? I have a 9 x 9 around the walls that is perfect for my space right now but in the future I’d like to expand it.
I am remodeling my house to accomodate a 11 by 22 foot trian room.
I live in Florida, and basements do not exist. I need to convert the house within its existing footprint to have a siutable train room.
My wife is retired, the girls have moved away, and the house is all ours now. This gives me the freedom to finally do what I want.
11 by 22 is plenty big enough for me. I play alone, so I really just need a room on the other side of the house where I can crank up the Rolling Stomnes and run my trains.
-Kevin
Haven’t posted in this week’s WPF yet (I have an ops session here today, so plan to post pics of it there later.) But here’s a pic from the entrance to the main room (pre-LED lighting).
Here’s looking back the other direction showing part of what’s behind the curved backdrop in the first pic.
This one looks into the corner you haven’t seen yet and is also where the Cascade Extension goes off to the next room behind the wall.
Overall the wide part of the room here is 16’ and it is about 28’ long from the door in the first pic. Next door is a long utility room about 8’ wide. This shot is of that section under construction.
Then here’s where that leads to…
And just a little more goes around to the right in this pic to the end of line at Snowden on the other side of the heater.
My layout in is a 10x20 single garage. It is a point to point shelf layout, but is built in modules so I can move it eventually.
Mine is an around-the-walls design with a central penninsula that includes lower deck staging, filling a 21’ x 18’ room. Big enough to include almost all of my “druthers”, and small enough for me to build and maintain.
Jim
Aropund the walls walk in U. 50 sq ft folded dog bone.
This is my first layout and it is a wopping 32" x 84" table that sits in one corner of my home office.
I am in the process of moving. I am tearing down my old layout of which 12x31 had benchwork up and some track.
The new layout is planned to be 17x37 with room for expansion if desired. I hope to start construction in the next 1-3 months once the move is finished and everything unpacked in the new house.
Paul
We moved/retired last summer from a bungalow in the suburbs with a full finished basement to a house built in 1900 out in the country. Our current home has a basement but with a fieldstone floor and is unfinished and is completely unsuitable for building a layout. Space is beyond limited, there are only two bedrooms on the second floor and the smaller of the two is allocated for my wife’s sewing studio. There is a three season sunroom which is uninsulated. I wracked my brains before we even moved as to where I could build a layout.
Until I accepted the fact that I will never have the luxury of the mancave that I had previously I made no progress. I finally decided that some layout was better than no layout. So I designed a small 30" x 48" layout with a track plan which I can expand as time permits. Being in N scale helped in that regard. I put together some nice benchwork to support the layout and put it on locking casters so I can wheel it out of the way in a corner of the living room when not in use. The DCC system is in a drawer that slides under the frame. I have plans to add fold down sections at either end to add staging and some more switching destinations.
The layout is far from complete and at 10 square feet in size it still has much work left to go on it. Until now space was never really an issue. But when compromises are forced on you there is always a way to keep going if you get creative.
OK, mine is an L shaped dog bone, along the wall, total bench top of 60 sq. ft., and 50’ of a continuous run loop. About half of that is “hidden”.
I switch 3 industries, one of which is “big”, as far as traffic in and out, and a transloading yard.
I did have links in my signature, but something was wrong with them, causing my post to “run off” the page. So I deleted them.
Mike.
My wife surprised me while I was away for a week and had a construction contractor friend split the double-wide and frame up a room for me. I couldn’t use all of the resulting space because the man door access to the garage was included in the partition. So, I ended up with an around-the-wall folded loop measuring 9X19.
I notice that in many instances we down-size, or retire and have to cut back, or kids come home…you know…just until…and some of us don’t end up living our dreams as a result. Yet, with some negotiation, and an expenditure of perhaps up to $5K, one could get a sea can set up in the back corner of the yard. I don’t mean a brand-spankin’ new one hot off the welder’s torch and paint booth, I mean well used and essentially disposable, but still worth some fixing to serve as a train room. If you have that garage, but it’s needed for stuff, maybe one part of the service could be used to serve the sea can and provide 20 amps. Between a couple of LED panels, a heater/conditioner running part time, and the demands of the layout, 20 amps should suffice…with some care.
Of course, if it were me, that’s where the kids would stay…[:-,]
My layout is as big as the run-chief makes it.
The last one in Aptos was about 18’ x 30’.
The one before in Clovis was more like 30’ x 60’.
I’m a Free-mo guy. So layout size varies, based on available space and number of contributors.
Here at home, I have a large-ish test track. It’s half-done. When complete, it will be 20’ square. “Around-the-room” double track on white painted plywood. Plus two small yards.
Ed
My home layout (HO) was 25’x50’ overall, but about 1/4 of that footprint was a furnace room. I had it for 10 years and then had to take it down when I lost the space in 2014.
My club’s HO layout is 50’ x 130’, and we’re about halfway done building it. Here are some shots taken of it back in the Fall 2016 train show we had in the club:
http://www.ssmrc.org/fall2016.aspx
Renting at present so, a little 18" by 33". Its tiny in HO, but it’s something.
I have been taken to task saying my layout is 15’ x 24’ and I guess that’s fair as it doesn’t fill the 15’ x 24’ room. So the square footage of the layout I don’t know but it is this big. We are currently looking for a new home and it must meet my wifes requirements for all the dogs (grooming facilities, usable acres to fence in for the dogs to run free, etc.) and my wants for the trains, which is about 500 Square feet for the layout, plus an office for building things. We have lots of affordable options where we want to move.
This is what I currently have.
Office
Bar with required lazyboy.
Music while waiting for the glue to dry.
It’s a good mancave.
Mine is roughly 12x18 not counting staging. Track plan based on the Moth Lake & Mount Ahab by Leonard B. (I would mutilate his last name if I tried to spell it right now)
My current one is 0 x 0’ (mismantled) but I used to have a 4 x 8’. Hopefully once things settle down and I find a permanent job again - albeit here or somewhere else, I’ll be able to begin building Layout 2.0.
I’m looking at an 18 x 12 space with a center peninsula interchange/staging area.
Just got rid of a 15x30 finished and I had more space I could have used. New place will eventually have a 13x11 when everything gets sorted out. Last layout only took about 3 years and couldn’t work on it full time due to it being non-heated. New space is in house
My layout that is being built in Florida (snowbird home) will be 13’x12’ 2 level with a helix in one corner. It will be able to be run solo or with a couple other guys. Point to point and for me, just fine. My other layout at home up in NJ is 20’x20’ 2 level with a helix, dogbone layout built for operations and when I’m solo running trains. Retirement is on the horizon and the CFO gave me the space in both houses so I not only keep my snaity, but don’t slip away in retirement, keeping me busy.
