How can one add to or delete Posted messages ?
I have been Posting photos for years without trouble. What is the new Set-up ?? The title “More” no longer appears for Editing a Text and Photo. What are you supposed to do? Can one Post more than one photo? How? Bob Hahn
You cannot delete posts in the new version - only a moderator can do that. What you do to call a moderator’s attention to the post is to hit the “report post” icon at the bottom left of the post (looks like a small warning triangle)
To edit a post, you click on the edit icon (looks like a pencil), located next to the “report post” at the lower left hand of the post.
Smile,
Stein
I believe the following is correct:
At the bottom of the post to the left of the REPLY button there are one to three symbols:
A triangular warning symbol, the report abuse button - on all messages.
A PENCIL, the edit button - on your own messages both NEW POST and REPLY.
A RED X, the Delete post button - on your NEW POST(s) but not on your REPLY(s). The X disappears when someone replies to the post.
Right - that is a point. There is in effect a “delete thread” icon when you start a new thread, and the thread only contains one post - yours.
There is apparently also a mildly annoying feature when reading a thread - on top of the thread is a screen button labelled “new post”.
It seemingly starts a totally new thread in the current forum instead of adding a new post to the current thread. To add a post to the current thread it seems like one needs to click on the “reply” screen button for one of the existing posts.
Someone needs to either change the text on the button to “Start new thread”, to remove the button from the page template, or to change what function gets called when one presses “new post”, so one actually starts a new post in the current thread.
Give it a few work days to see if it gets resolved in the flurry of post-upgrade fixes, and if it still is there and still is annoying, someone can use the Customer Support web form (https://secure.kalmbach.com/customer/ContactForm.aspx) to file a bug report for the webmaster.
Ah - you figured out how to edit the text of your post, and instead of just posting new questions by clicking on the “Reply”
