how do i insert my atavar
Hi
I would like to have my “atavar” on my posts the system will not let me do it,what is the correct proceedure.
Patrick
Go over to the right side of the screen, click ‘Update Profile’, click the ‘Avatar’ tab, click ‘Enable Avatar’ if it isn’t already selected. Click browse, select the file that contains your avatar, click ‘Update’,
Do you get an error message when you try to upload it?
Not sure what “the system will not let me do it” means. I assume you’ve gone to Update Profile and clicked on the Avatar tab.
One thing to try is explicitly logging out and then logging back in again. That’s been known to clear up problems like this.
Hi All you guys
I am getting an error message which seemes to come from a fault at model railroader terminal.
will try again later.
PATRICK
All the information provided above is good information. Because the server was down several times and had to be stood back on its feet, it may be that your cookies are no longer being accepted/recognized. Log out completely, or if you aren’t averse to it, clean all the temp files off your hard drive…use CCleaner or your windows application. Once that is done, return to the log-in prompt and try again. You may find that you will be okay.
If it persists, please sent an email to customer service and inform them of your difficulty. They may have to change a setting on their end.
-Crandell
