I’ve got a photobucket I just need to find out how to get the photos from point P to point F.[banghead]
select the pics you want tp post here and on the lower left side of the screen (at photobucket) there are 3 or 4 links shown, click on the IMG link,copy it, paste it in your post here. Be sure to hit enter after each link paste.
I’m not sure I understand
What part is it that’s giving you difficulty?
The “Post URL” stuff. And another thing. Whenever I entered the URL as it told me I got a red X instead of a picture.
Go to your Photobucket account. Pick the photo you want to post; under each photo are several URLS, choose the one with [IMG], click on it. A popup should say “Copied”; it has been placed on your computer’s clipboard memory.
Go to the forum where you want to place your photo. Right click on your mouse, choose “Paste”; this will copy the [ IMG ] link in your message. Your photo should now be in your message. To see, select the “Preview” button at the bottom of the message block.
Give it a try!
[*IMG]http://img.photobucket.com/albums/v651/andrechapelon/b2290df0.jpg[*/IMG]
The only difference between the actual picture and the above line is the asterisk in the code. If you look at the four boxes below an individual picture, you will see that the 4th one begins with the code listed above (without asterisk). All you really need to do is left click on that box. This will copy the code to your clipboard. All you then need to do is paste from your clipboard into your post.
Edit. Forgot to warn you. Hit enter after you paste from the clipboard and do so each and every time you paste a link.
Andre
Hooray![:)][:D][8D][swg] Thank you
