Ok, this is a stupid question. Tsunami-equipped Genesis GP7. I was running it with a JMRI throttle (from the computer) and hit “STOP!” … This is the button above IDLE under the verical slider for speed. I did not mean to do this, but it was a slip of the mouse.
Now the engine won’t respond to throttle when selected from any throttle (including the command station)? How do I initiate the startup sequence?
I’m with Elmer on this. This is not a decoder issue but a command station issue. Try resetting your command station. You may need to clear the JMRI throttle also.
As far as I remember, it did not shut down the DCC system. I did hard power cycle the DCC system (twice) but have not reset the command station. I am on Digitrax.
I will reset command station, maybe flush the loco memory of the command station first. Then go to decoder reset.
That was it, Joe! An internal memory flush on the Zephyr Xtra brought the loco back to life. While I was at it, I messed around with sound programming a bit as well.
Glad to see it worked and that you are back in business. I also run with a Zephyr and have found that while it is pretty stable a “good flush” of the system periodically keeps things running smoothly.
[:)] wow, did not think of that! Next time I will climb on top of the engine with some ether while I ask my son to repeatedly go to Speed Step 1. Should be easier.
Naw!..He won’t need either one, the explosion will occur in the diesel cylinder of the prime mover and that is what you want. No electric needed, except for the starter and then if it has an air starter, you don’t even need any electric at all. Now if it was a gasoline engine and you used too much ether, it’ll blow the head off. [:D] Oh and keep a few fire extinguisher’s around, if your running Nitro Methane, now that will be an explosion. [(-D]
I was running one of these in late 64, at many drag strips, back in the days when I was young. The speed days, I call um’
It’s a 1964 Ford Fairlane ‘‘Thunderbolt’’ Factory installed 427 dual quad carbs, the holes are for air-intake to the rather large air cleaner. Rated 600+ horsepower. Was street legal but not recommended. Was almost impossible to insure, without big $$$$. [:D]
You’ve also exposed the plot hole in the show Revolution. Nothing electrical works. So how come no diesel engines with mechanical injection are working? They require no electricity to run. On the plus side, they do have some steam trains they use.
.‘’ So how come no diesel engines with mechanical injection are working?‘’
They probably forgot to flip the mechanical pump switch to manual, before trying to start. You got one shot, with an air starter, to fire up before the air runs out. [:-^]
They could always use a steam engine as a pony engine to start one up, since a gas-fired pony engine won’t work.
Or a hand pump to repump the air - sure it takes forever, but it can be done. Or use some horses to get it to the top of a hill and bump start it. Big rigs, pickups - but also stationary engines that could be used to run various equipment with mechanical links - thinking belt-driven machine tools and stuff like the wya iut was before each machine had its own electric motor.
