All I have set up for Christmas is my LGB G scale DC train. The question is this: If I want to run any Lionel accessories like gateman or a crossing gate (which are closer to G scale anyway) can I still use the track power to operate them. I’m sure I can use a weight activated contactor under the track, but what about power. I am using my DC power pack for the LGB train and it has a Variable DC, a fixed DC, and an accessory power posts.
I think I’m confused about what kind of power goes to the tracks on my Lionel AC/DC?? Don’t the accessories run on DC power?
Any advice would be helpful, before I burn down my new Christmas version of Gateman.
DC is fine. I convert the AC to DC on my layout to run the gateman because it is a lot quieter. However, I doubt if the track power on an LGB layout is sufficient to activate the gateman. I would power the gateman separately and put a pushbutton in series with the power so that little people can activate the gateman by themselves. Good Luck…
A complex question. Almost all Lionel trains,except for a few really cheap sets, run on AC and up to about 1998 or so most came with AC/DC motors. Your gateman and crossing gate are just a coil and plunger so I see no reason for them not to work on DC. The only thing to consider is: A DC coil could magnatize the plunger. Many say it doesn’t happen but every repair manual say’s it can.
I have an HO power pack with fixed AC accessory posts that puts out 17.8 volts AC on a meter. The Nutcraker Gateman comes with a push button switch, but the instructions say say it operates best between 13-15 volts AC. I was going to buy a CW-80 if that voltage is too high to work or could burn it out. (the CW-80 comes with a programable accessory post)
The 17.8 volts is probably fine unless you leave the gateman powered on for long periods. The higher the voltage, the more crisp the action. I have run my gateman using FasTrack TMCC voltage which is around 18 volts. There were no problems.
If you go for the CW80, don’t rely on your voltmeter for setting the voltage. In the middle of the CW80’s range, the voltmeter will read about 4 volts low, which means that you will set the voltage about 4 volts high. Here’s my latest guess at the CW80’s actual RMS output:
