how do i wire my lay-out ???
i am runnig all tmcc locos with legacy system and fastrack., and i want to have 7 seprate power blocks ( because i have 7 cw80 transformers to use) . do i only need to cut the center rail to isolate transformers on each block , or is it cut center rail and one outside rail. and leave the rail the tmcc base is hooked to the only continious rail. i am confused because if you look at the underside of a lionel fastrack block section there is a removable wire for each of the three rails.( why would you ever need to cut outer rails ?? ). and will the adittion of fastrack switches change any thing if the are added in between block sections. thanks for help.
I have next to no experience with TMCC, however I can tell you that the middle rail should be connected throughout all the blocks. The blocks should still be isolated with a block section though. And no, switches won’t, or at least should not cause a problem. Even better, they have new TMCC fastrack switches now.
Bigdaddy, You certainly bring up a number of interesting questions. I am not a TMCC expert, but have had some experience with it all. Let me respond to your specific areas;
[quote user=“biggdaddy”]
i am runnig all tmcc locos with legacy system and fastrack., and i want to have 7 seprate power blocks ( because i have 7 cw80 transformers to use)*
It would certainly help to have a better idea of what your track concept or plan is. Also what your other power needs are. For example, if you have any accessories, or building lights, why not use 1 of the transformers for those items. That way you can adjust the voltage independently. Also, if you develop some problem in the future it would be much easier to troubleshoot. EVEN if you don’t have any of those thing now, I certainly would consider holding one of those transformers back for future use. Another factor is the CW80 xtransformer is not known as one of the best xformers ever produced. They have a history of problems, and a reserve transformer would be a great idea.
Some folks may argue you only need to isolate one or the other, then have it under a switch activation. Personnally, IF you doing and/or want block control, I would totally isolate them from one another, both center and outside rail. I would have the tracks wired in parallel with two separate wires. A bus or common line is easy and a little les expensive, but when you have a problem is much more difficult to troubleshoot and resolve. Also, WHY do you want blocks? TMCC operation eliminates the need for blocks by having complete command control of each engine. The biggest advantage is to be able to remove power from specific areas and turn them off.
