Not a big waterfall like ArtHill’s Yosemite Falls, but a narrow canyon filled with boulders and a series of smaller falls an inch or two high. I think I could do a lake, lazy river or stream, but I don’t have a clue how to make waterfalls look good.
For water cascading over boulders, Woodland Scenics Water Effects would be one choice.
For a curtain of water, you could build the falls with strips of Scotch tape then apply coats of matte medium until you get the effect you want. I’ve also seen a similar technique done with pipe cleaners to shape the falls.
I don’t have any pictures because I haven’t built my falls yet but I intend to do something similar to what you have in mind.
I saw in one of the MR books where the author (I think it was Lou Sassi) used a strip of mylar for the backing of his waterfall and coated it with Realistic Water, or one of the other imitation water products available. The author secured the mylar at the top of the falls (probably with silicone), bent the mylar to achieve the radius arc that he wanted, and secured the other end at the bottom of the fall.
Initially, his waterfall was somewhat uniform but he broke that up using WS Water Effects (or something like that) for the foaming water effect. It looked very convincing.
Chip, I don’t know how big of a waterfall you are looking to build. I would think that 2 or 3 mylar strips, bent at different arcs, might make a nice cascading waterfall effect - especially as it hits rocks on the way down the canyon wall.
I remember another article where the author used (dare I even say it) clear caulk as the basis for the waterfall form, then covered it with more traditional water products for the final effect.
I installed and painted rock castings along the face of the fall. Then, I laid verticle beads of a clear sealent called LEXEL over the castings and dabbed some along the base of the falls for rapids. After then LEXEL cured, I drybrushed on some white paint to both the falls and rapids. I finished up with a couple coats of acrylic gloss medium to bring the shine back up.
Man-made:
I created the dam using WS retaining wall castings. The stream is WS course ballast. Then, I made the outfall from a piece of .10 clear styrene, drybrushed with white paint. After, installing the outfall, I piled up some talus at the outfall’s base. When the glue was good and dry, I covered the talus pile, and stream beneath the outfall with LEXEL. Finally, I drybrushed the rapids with white paint, and covered the outfall and rapids with acrylic gloss medium.
I also used LEXEL to make a fast moving stream, but don’t have any pics at the moment.
How to get the disturbed water at the foot of any waterfall… where the water tumbles around like the water in a washing machine.
How to think through the effect of moving water on the river bed… I think that I might be able to offer some ideas on this.
Ages ago (I think about the Pleistocene) I saw a college presentation about water flowing down a slope. They used a tank full of spheres of 100% constant size and weight… they tipped it at a slight angle and ran water in at one point at the top. Apparently they had expected the water to run straight down to the bottom… but it didn’t… it began to “bounce” / oscilate. Which meant that instead of running straight down the slope it began to dig a pit… and when it nosed down into the pit it got deflected one side or the other. So now the water began to go across the slope, which wasn’t logical - so it tried to ge/ tended toward the low side of the cross-slope coarse… and would turn back down the slope… where it would begin to bounce again as it built up speed and therefpre dig a pit… – This isn’t the best description but what I’m trying to get over is that rivers wiggle sideways because they wiggle/bounce vertically. – Then this all gets messed about by the surface not being made up of 100% consistant material.
The resuylt of the last is that there is a whole lot of stuff going on in a river bed that we don’t see.
The product of all this stuff is that most waterways alternate deep bits with shallow bits - as the water drops it scoops out a deep bit and when it bounces up it allows / passes over a shallow bit. At the same time when it digs in it can cause itself to divert sideways.
Except where the dig in hits a hard material it is going to start to scour out a hollow… this means that while a dig-in initially causes the water to divert sideways the “corner” will a
