How do u get the Pic on the bottom of Ur Comments,etc???
[:(]How do u get the pic of a train or somethin underneath every comment u post cause i want to put a pic on mine…[V][?][:(!][;)]
Hello scns railfan. Go into you signature. Go down to the middle or so, and you will see 2 things: Signature (text version) and another one Signature (text and graphics version). The one that you will want to use is the text and graphics version. The picture that you have to use must be from the internet. When you have found your favorite one, right click, click on properties and highlight the URL address. When you are finished with highlighting, right click again and click copy. Then paste it in your signature, and put [ img ] and [ /img] at the front and rear of the address. Make sure you take the spaces from the img and /img to come up with the pic.
Actually, quote me on the pic I will post. It will show you the form that you need to make it appear
Hope it helps.
It’s Not working
Works for me.
Did you put the “img” codes before the URL and after?
Quote one of us and it will show what you have to put before and after the pic. After the URL is pasted to the page, the img tags have to be put in front and back of it, Make sure you put the [ at the front, img in the middele, and ] at the end. Now, at the end of the adress, put this[ and the /, followed by img and then close it with this ].
ok it works!!!thanks u guys
