I wonder what tool I should use to drill holes for Kadee Nut-Bolt-Washer? I can read the following on Kadee’s webpage.
Die-cast metal Nut-Bolt-Washer Shank press fits 1/32" hole.
Where do I get the drills in that size?
Your LHS should have what you’ll need,offhand I’de say it’s about a #70-75 bit, but it maybe smaller, you’ll also need a pin vise to drill it.
electrolove? Can I make a suggestion? I know you live in Europe and you really don’t have a Local Hobby Shop. Why don’t you go into your profile and put your location or country in so it shows up under your name? This way people won’t assume that it’s as easy as a short car ride to get what you need.
You can order what you need from www.micromark.com they have plenty of small drill bits and drill bit holders so you can finish lots of modeling projects. Just go to “hand tools”.
Jerry
Neutrino:
A very good suggestion. It’s done.
I will look at micromark and see what I can find, thanks.
A 1/32" drill bit is equivalent to .0313 inch, .7950mm, or a Number 67 Drill Bit.
cacole:
Thanks, this is exactly the info I need. Inch to a Swede is very strange. I know that 1 inch = 2,54 cm but when you guys are talking about 1/32" and things like that, I’m totally lost [:D]
Just because I’m very curious. Do you use mm, cm and meter at all in the US?
BTW: Number 67 drill, what system is that?
Electro,
A pin vise and a tap set are essential tools in my opinion. I will usually
buy bits as I need them, but I have a hobby shop within five minutes of
my house. You might think about getting some of the basic sizes of bits if
you don’t have quick access to them. Good luck, Dave
electrolove,
With practically every hobby item made in China today, metric tools are becoming a necessity. I spent 26 years in the U.S. Army and our topographic maps have always been in metric measurements.
Machinists’ drill bits are graded according to a “wire size” standard that is based, loosely but not precisely, on thousands of an inch. I have a set of 20 wire size bits purchased from Micro-Mark, which someone else suggested to you, that are numbered from size #60 to #41, with #60 being the smallest. Wire size bits are equivalent to the following:
Wire size / inch / Metric (mm)
80 / 0.0135 / 0.3429
79 / 0.0145 / 0.3683
78 / 0.016 / 0.4064
77 / 0.018 / 0.4572
76 / 0.020 / 0.5080
75 / 0.021 / 0.5334
74 / 0.0225 / 0.5715
73 / 0.024 / 0.6096
72 / 0.025 / 0.6350
71 / 0.026 / 0.6604
70 / 0.028 / 0.7112
69 / 0.0292 / 0.7417
68 / 0.031 / 0.7874
67 / 0.032 / 0.8128
66 / 0.033 / 0.8382
65 / 0.035 / 0.8890
64 / 0.036 / 0.9144
63 / 0.037 / 0.9398
62 / 0.038 / 0.9652
61 / 0.039 / 0.9906
60 / 0.040 / 1.0106
59 / 0.041 / 1.0414
58 / 0.042 / 1.0668
57 / 0.043 / 1.0922
56 / 0.0465 / 1.1811
55 / 0.052 / 1.3208
54 / 0.055 / 1.3970
53 / 0.0595 / 1.5113
52 / 0.0635 / 1.6129
51 / 0.067 / 1.7018
50 / 0.070 / 1.7780
49 / 0.073 / 1.8524
48 / 0.076 / 1.9304
47 / 0.0785 / 1.9939
46 / 0.081 / 2.0574
45 / 0.082 / 2.0828
44 / 0.086 / 2.1844
43 / 0.089 / 2.2606
42 / 0.0935 / 2.3749
41 / 0.096 / 2.4384
40 / 0.098 / 2.4892
39 / 0.0995 / 2.5273
38 / 0.1015 / 2.5781
37 / 0.104 / 2.6416
36 / 0.1065 / 2.7051
35 / 0.110 / 2.7940
34 / 0.111 / 2.8194
33 / 0.113 / 2.8702
32 / 0.116 / 2.9464
31 / 0.120 / 3.0480
30 / 0.1285 / 3.2639
29 / 0.136 / 3.4544
28 / 0.1405 / 3.5687
27 / 0.144
I had students (back in the day when I was a professor) who swore that there was no need for them to learn metric, that they could do their physics labs and homework just as effectively in English units as metric.
Talk about your provincial thinking! [:p]
I would sometimes put a question on first homework assignment (which would generally be about units algebra) in which they had to convert ‘c’ (the speed of light, 2.998x10^8 m/s) to furlongs/fortnight (perfectly valid English-system units). [}:)] While it didn’t make them happer, it typically shut them up…
Brian Pickering
Wow… furlongs per fortnight !!! I remember that unit from my own college days many moons ago.
It was part of one of the standard wisecracks from the engineering students when some situation struck them as particularly ridiculous: “Could you give that to me in furlongs per fortnight, please?”
Thanks for the reminder.
Ed
edkowal and bpickering:
Furlongs per fortnight, I have never heard of that, and I do not think I’m missing it either. [xx(] Thanks for the great answers. I have said it before and I say it again, I love this forum. [:D]
cacole:
Confusing, hehe, YES! But with a table like that it’s pretty easy. Thanks.
