A neighbor who knows I’m a model railroader recently gave me a box of accessories, a Varney F3 locomotive, (which I got working) and an MRC power pack. My question is how can I tell/test if the power pack is safe without possibly frying anything, or myself? It’s an MRC TRAIN PACK, model T2B with an input of 115V 60 AC, and output of 15V DC 1000MA 10W 17V AC. The cord looks like it’s in good condition with no cracks, but beyond that I don’t know if the unit is good. Also, does anyone have an idea as to the age of this unit?
Do you have a VOM meter? You could hook up the leads to it and run the potentiometer up to max and back down and see if the voltage runs up to something in the neighborhood of 12 to 16 volts and back. If the meter goes the other way switch the polarity (direction) on the power pack.
Maybe Randy can say definitively, but putting out too much power seems like an unlikely mode of failure to me. Whenever the question comes up of how much power do I have, a voltmeter is almost a necessity. A Harbor Freight $5 voltmeter is good enough.
The T2B on Ebay, for $13 BIN, has a bronzeish case and the address is Brooklyn 34, NY Zipcodes started in 1963. Howard Zane uses MRC transformers to run his turntables. While I didn’t see a T2B, it’s a potentiometer and old doesn’t mean much. Someone told me that when the reactivated the USS Missouri for Vietnam, they still had tube system electronics and FDR stationary in the admirals cabin.
The specs I found on the TB-2 says it has a Rheostat, if so You will have to test the voltage under load to see if the rheostat works. Use an automotive bulb as a load and check to see if you can vary the brightness of the bulb with the throttle. Try it in both forward and reverse.
First I would make sure the 120 volt AC cord has no cracks in the insulation.
I the pack has a metal case and quite old I would check on the AC scale with the meter between the metal case and the outlet screw on the wall for AC leakage in case the insulation on the transfomer inside is old. Happened to me many years ago. I put a three wire cord for grounding the pack on it. A GFI prptected outlet might show it.
Connect an auto light bulb for a load to the output. Use a multimeter to measure the voltage and current.
While that old power pack may be fine and actually work, it won;t be able to control most newer trains, because of the rheostat. That old varney loco would run fine on it, but newer locos draw a lot less power, which combined witht he rheostat coontrol mean they will tend to take off at full spped when yoou just barely crack the throttle.
If it works (and yes - there’s is practically no chance it can put out too much voltage. Worst case would the the rheostat is shorted and it put out the full 12V or so all the time) it might be useful to power accessories or something.
This is the easiest and safest way I know of to test a throttle pack. I combine the buld with a voltmeter. This is a dynamic test that tells you a lot more than simply using a voltmeter.
An 1157 bulb with both filaments in parallel is my choice for a good load.
Like Kevin said, get the 1157 bulb. Go to auto store. Get the socket also. Tie both wires together. Use the link I posted earlier for two meters. Curent and voltage.
