How is the radius of Atlas sectional track measured
I use the 22"R and 18"R Atlas “snap switch” for street trackage, they work fine for that sort of thing.
Sheldon
Hello All,
By “Ten Wheeler” do you mean a 2-6-2, a 4-6-0, or a 2-8-0?
What size tender?
Type of fuel- -coal or oil?
That wheel configuration seems large for switching duties- -both in terms of length and fuel/water- -consumption.
On my HO 4’x8’ pike the “mainline” consists of 180º asymmetrical curves at each end comprised of 15- and 18-inch sectional track, with 2-inch transitions between the differing radii.
My track plan allows for 0-4-0 and 0-6-0 locos along with four-axle diesels.
The upper and lower coal unloading/loading sidings are comprised of PECO #2 turnouts (ST-240 & ST-241).
As is the wye made up of PECO #2 turnouts with two (2) 15-inch radius Atlas sectional track for the legs to an Atlas Mark IV wye turnout at the head end.
Rather than rethinking the track plan, I suggest you reconsider which locomotive can work this yard most efficiently.
Unfortunately, I’ve become adept at “shoehorning” track into small spaces.
This comes at the expense of smaller locomotives and shorter rolling stock with tighter curves.
In modeling, compromises need to be struck to achieve reliable running.
For this situation, I would err on the side of caution, using small radius sectional track and turnouts with smaller locomotives.
Hope this helps.
A “ten Wheeler”
Hello All,
I’m a diesel guy- -thank you for the clarification.
Hope this helps.
