How many layouts??
Hmmm. Let’s go back into ancient history:
When I was four or five, my dad and I had an HO layout on a 4’x4’ sheet of plywood. It was a simple folded oval using the traditional sectional track, open-girder bridge, and plastic trestles. We tried using papier mache to build up under the trestles, but it didn’t work well.
When I was about 9 or 10, I got a pre-made layout as a Christmas gift. It was molded foam, pre-colored, with the same up-and-around plan as before. Some lighter foam served as the roadbed. It came with buildings, and a Conrail F9 engine and some cars. It was destroyed by my 5-years-younger sister in a fit of jealousy by her poking holes all across it, and bending up the track.
When I was in college, my mom’s boyfriend got out of the N-scale stuff he had, and gave it all to me. This was just track, but I got a 4x4 plywood sheet and laid down some simple loop-with-passing siding stuff, and had fun with it for a while.
Later, I took off all the track, and re-cut the plywood to make a hexagon shape, and put a folded-figure eight on there, with some spurs. I did it using cork roadbed, and had painted the plywood brown, and actually applied ballast. But, scenery was a challenge, and starting with a flat sheet of plywood didn’t make for much interest. This layout moved with us from Iowa to Minnesota, where is stayed dormant until my son saw it and prompted me to rework it.
The story of that rework is in another thread (see the link in my signature). But using the same hexagon shape, we did a simple loop of track in order to make it easy for my son to play with the trains, and to spend time doing the scenicking that I hadn’t really figured out before. That’s progressing nicely.
Recently, I acquired two cast-off HO layouts on rectangular plywood sheets, one 3’4"x5’ and the other 4’x6’. I’m looking at bolting these together and trying the Woodland Scenics subterrain system for scenery on it. This won’t be a simple loop, but have som
On my first - third iteration… Founds problems like too sharp of curves and had to expand here and there just to keep the locos from derailing, etc.
Even planning isn’t full proof but does help immensely.
Peter
Depends on what you want to call a “layout” !! I had a c.1958 American Flyer “S” guage train set with the track (Atlas snaptrack by the way - yes they made S guage track!!) nailed to a sheet of green sheetrock. Could only play with it during Xmas season.
Then I had a very early (c.1969) N scale train set, didn’t last too long.
Went to HO and became a “for real” model railroader in 1971, but had trouble (brass track) and by 1973 had started work on a 4-1/2’ x 10’ O27 layout which I ran (using largely Atlas scale O cars) in various forms until the early eighties when I built an 8’ x 16’ O three rail “hi rail” layout using scale sized equipment and buildings etc, 36" radius curves and Gargraves track.
Went back to HO in 1987, used benchwork from the O layout for the new layout until about 2000 when I began a smaller (bigger aisles) 6’ x 16’ HO layout that I have now. This layout will be demolished in a few weeks / months when we move, don’t have the new house yet so not sure what next layout will look like - might have to go to N scale if space is limited !!
I have had two…one was a completed failure, but I did manage to pick up a knack for the MR gig and my second one is pretty sweet. I intend on keeping its basic form for a while. I’m gonna have a website: modelrailroading.tripod.com sooner or later with pics of my projects and stuff
I am on number 5, each change precipitated by a move. I am done moving so I hope to fini***his one.
I’m on layout #2. Like most newbies, I started out with a 4x8 table. That lasted nearly 10 years. By the mid-90s, however, it was starting to show some age. The table had started to sag in the middle, and most of the equipment was wearing out. I saved what I could (structures, rolling stock, power packs, etc.) but scrapped the rest. I built an HO scale sectional layout based on plans in MR that’s roughly 10x16. Right now, the scenery is pretty crude (and nonexistant in some places) but at least I can run trains.
As if that wasn’t enough, I have a little N scale layout as well. This is just a loop of track on a leftover 2x4 piece of plywood.
