I don’t use DCC so my question is based on DC w/control panel. I have 2 older MRC Tech II’s, which I got real cheap, brand new in their boxes, never used. Once I get this layout under way and start adding lights to buildings, crossings, signal lights, street lights, etc. how many additional power packs (power supplies) should I expect I will need? One MRC II has three outputs; variable DC (to 14VDC), 18.5VAC and fixed 15VDC with a total of 17VA. Now if I understand Volt-Amps (VA) you must divide the VA by the input voltage (i.e. 17 divided by 115) which gives me aprox. **.**15 amps continuous load.
I read here on MR forum that some power packs are 2.5 to 5.0 amps. Is this really VA or are these ratings true continuous load amperage? Is this only the variable output or total output? If it is true continuous load amperage then do I not have enough power to run 2 locos on a large consist? Will I need to buy additional power supplies to run the signals, crossings, lights, etc.?
