At this point I have around 170 feet of rails, when done I would guess I will have around 270 to 350 feet. I like big.
Track will use 2 power supplys so I can run DCC and DC Blue boxes. I would guess not worth the cost to up grade them to DCC.
With the uses of rubber joiners and electical swithes I should be able to run either main line or whole track DC or DCC.
Here are my goals.
1 Be able to run three Blue boxes at the same time DC.
2 Be able to run 5 PKs at the same time.
My current DC power supply is a MRC 1440 and if I done the math right only 0.96 amps. It will run 2 blue boxes but gets warm, added a 3rd one and shuts down pretty quick. It handels 3 PK2’s with no problem but they will be DCC so that does not matter.
My first DCC unit will be a Bachman E-Z . Before you tell me it is a waste and I wont like it I am buying from Tstage at a prices I cannot say no to. More than likely I will out grow it like Tom did but you got to start some where. If I am right it has 1 amp of power. Do you think it will power between 4 to 5 PK’s?
Do you need more power when you added more rail? I will have power taps (is that the right term) about every 10 feet of rail and 80% is flex. I was ready to buy a nasty power supply for the HO slot cars then I learned a easy way to do power taps for them. (way harder than rails) and found the little wall warts and good Parma hand controler I was hitting sMph of 486. Coverd 160 feet of track in around 11.5 seconds.
On the DC side, would the MRC Teck IV 2600 or 2400 handle 3 Blue boxes? I was hot and heavy after a MRC 2500 II but I am not sure I want to spend that kind of money to run 3 blue boxes.
Thank you for the answers that are coming.
Idiot Ken asking questions again.[:D]
