LGB has 4 types of sectional curves: R1, R2, R3, and R5.
R1 - 12 sections to make a 360 circle. Brass #11000 and Nickel Silver #14110
R2 - 12 sections to make a 360 circle. Brass #15000 and Nickel Silver #14500
R3 - 16 sections to make a 360 circle. Brass #16000 and Nickel Silver #14600
R5 - 24 Sections to make a 360 circle. Brass #18000 and Nickel Silver #14800
For a room, you will probable use R1 or R2 curves due to space, but be wise of what type of locomotves/cars you will be using. A tip: The bigger the car, The bigger the curve.
They, LGB, also has numerous types of sectional straights, from 1 foot up to 4 feet in lenght. If possible, get the larger track, as there is less that can go wrong. Such a electrical conductivity, only a problem with track powered locomotives.
Now, Brass vs. Nickel Silver. I use Brass for my outdoor layout, and the only downside I can see with Brass is that it darkens very quickly, this really depends on your personal tastes, due mostly to weather and a little to use. I do not use Nickel Silver as it costs more than Brass. For an indoor layout, it really depends on how much do you want to spend.
If it were me, I would use Brass, due to its lower cost, just my two cents.
