In several recent threads the topic of sprung trucks and various brands of wheelsets once again was discussed.
I have gathered some engineering information in an attempt to explain how model trucks actually work, why some roll better than others, why equalization matters, and hopefully dispel a few myths.
Myth #1 - The car rides on the points of the axles.
Myth #2 - Our cars do not weigh enough to make sprung trucks “equalize”.
Myth #3 - Rigid trucks track just as well as equalized trucks.
First, some basic engineering standards for model trucks and their components, from the NMRA:
Interestingly, the axles on Intermountain wheelsets are nearly identical to the design shown above.
The key feature being the small axle diameter outside the wheel, resulting in a smaller axle cone.
Well no, actually the cone of the truck journal contacts the cone of the axle tip, but not on the “end” or point of the axle, but rather like this:
Notice from the NMRA specs that the journal cone is 60 degrees minimum, while the axle is 50 degrees maxinum and the max axle length is less than the minimum journal span, creating a minimum standard for side to side play. Interestingly there is no maximum spec for side to side play.
It is assumed that as long as the axle stays in the truck, gravity will center the axle.
This leaves a 5 degree difference on the weight bearing top side to minimize the contact patch of the axle onto
