How to build a "walk through" for my first layout?
Hi, This is my first attempt at an HO train layout. I want to be able to lift the board with the track on it and walk through into the center area of the layout. I cannot seem to find any information on the proper way to accomplish this. Any suggestions would be appreciated. Thanks, Kevin
There are four basic posibilities, and variants within each:
  1. Hinge up. Hinged at one end, lifts to clear walkway. Think castle drawbridge.
  2. Hinge down. The reverse of the hinge up, useful where there might be overhead clearance issues.
  3. Lift out. Not hinged - just pick it up and walk through, then put it back.
  4. Swing gate. Like the lower half of a Dutch door - but with tracks on it.
Which is best for you will be determined by your specific situation and your personal construction skills.
To get more than you want to know about the specifics, enter any of the group names, in quotes, in the Search Community block to the right under your profile.
A couple of general rules, applicable to all potential holes in the trackwork:
  • The movable section of roadbed must be solidly supported and precisely aligned at both ends.
  • There has to be some kind of electrical interlocking system, to keep trains from plunging into the abyss when the movable section isn’t in place.
Several years ago, when I only had half of a two car garage to work with, I was on the verge of putting in a bascule bridge designed to allow access to my central operating pit. Then my wife ceded me her half of the garage, and the need went away. Now I have walking access to my entire layout, and no need for a moveable section of through track roadbed.
Excellent advice, Chuck. The only thing I can add is…Welcome aboard! [#welcome]
