How To Connect Power To SE8C
The PS-14 does not have two wires without ends. Instead it has an adapter. How does Digitrax expect you to connect a power supply that is not configured.
Just like you would any other situation where you need bare wires. Cut off the plug, and strip the wires, both skills you will need anyway to run the signal wiring.
