How to cut phosphor bronze wire
I plan to use Tichy phosphor bronze wire to model the brake piping on a freight car. I’ve looked on the internet and can find lots of ads for sellers, but nothing on how soft the metal is. Would it be safe to use rail nippers on this, or side cutters? Or should I use a dremel with a cutting disk?
Side cutters are my choice.
A cut off wheel is over kill. An old 11 xacto blade will work
I have an old pair of rail nippers and use it. AFAIK, it hasn’t damaged the nippers, like some of the other stuff that caused the damage to the nippers. That said, I don’t use my new nippers to cut it.
I stock Tichy phosphor bronze wire from .01” to .04” and it cuts fine with normal wire cutters without dinging the cutting edges. The Harbor Freight 5” Micro Flush Cutters work great!
Mel
My Model Railroad
Bakersfield, California
If you are worried that the alloy has work-hardened in drawing or manipulation you can briefly anneal it at 400 to 600C before you cut it.
I agree with Henry, and use an X-Acto #11 blade to cut almost any size of brass and phosphor-bronze wire, and also for aluminum and brass tubing. I always work on a hard surface (usually glass).
Smaller diameter wire can be cut with only suitable pressure on the wire (use the heel of the blade, not the tip, as the tip can easily snap off).
For larger wire diameters and tubing, I place a short length of masking tape on the glass, then place the item to be cut on it, rolling it back-and-forth by applying pressure with the knife.
The knife will also cut small-diameter stainless steel wire, but it’s not something that I use all that often.
For small-diameter music wire, side-cutters work well, unless a clean (not deformed) end is needed. For that and larger such materials, a cut-off disc is a good choice.
Incidentally if you need an undeformed end, cut the piece just a tad long and suspend the ‘overlength’ into a ferric chloride (or equivalent) solution until it is the right length ‘chemically’ – or mask off the correct length of formed wire directly as if etching.
A file is also an easy way to clean-up messy cuts.
I use a very expensive pair of Professional quality Mac Tools flush cutting nippers.
These provide a square cut non-deformed end that a single pass with a needle file will make perfect.
Normal diagonal cutting pliers will work just fine, but will need more filing to true the ends.
If you need precision lengths, it is best to cut it a little long, and file to length.
Tichy Phosphor-Bronze wire has always served me well. It is not so hard that you need any special tools. There have been a couple of good cutting methods mentioned, try them out and go with what works best for you.
-Kevin
If you are using wire cutters, nobody has mentioned the need to contain the piece that is being cut off to prevent it from flying away, or worse, impaling you. Don’t use your finger tip! I have stuck pieces of thin phosphor bronze (and other) wire into my fingers more than once. Safety glasses are advised too.
Dave
As with trimming other kinds of wire or parts, or installing fidgety little springs or other parts … work with your hands (and the tools and parts) inside a suitably sized plastic baggie. That may not stop the wire end from twanging when it snaps, but will contain it when it stops moving. I find that even using an operating microscope you can see pretty well through the clear side of the bag.
Dave, thank you for the safety reminder.
SAFETY FIRST! Never allow your hobby to bcomre the reason you need medical attention.
-Kevin
I just use the correct tool for the job! A little over kill for the Phosphor Bronze wire, but excellant results along with able to safely cut just about any wire material made:
https://www.xuron.com/index.php/main/consumer_products/3/17
Take Care, All, [:D]
Frank
PS. When I got Mine yrs. ago, they were lower in price…
OK… Back home and I can post pictures…
These are the Mac Tools flush cutting nippers I use.
All my bronze wire if packed away, so I cut a piece of 12 guage solid copper wire to show you how they cut.
One side (one the left) is a perfect square cut that just needs one pass with a file to make perfect. The other side is badly deformed.
I cannot express how well these pliers do precision square cuts. They are expensive, but well worth it.
-Kevin
When using the tool I posted a link for above, it will eliminate any need to dress the cut with a file or other means. The shape of the jaws produce a shearing action which does not distort the material like side cutters do.
Saves a lot of time and aggravation when installing hand rails and such. The part cut will fit right in the hole drilled for it without any dressing of the cut that using side cutters by it’s own design, distorts the cut.
Take Care! [:D]
Frank
Man that is nice!
After all the input (very much appreciated everyone) I decided to use an X-Acto blade for my first experiment and indeed it worked fine after a bit of work. Based on that I’ve just been using rail nippers for the rest of the cuts and no problem at all, with a bit of filing to dress up. I’m also going to invest in a pair of the Mac Tools flush cutters for the future - they’ll also be useful for other general household projects. Again, thanks all, and especially appreciate the safety reminders.
