In my previous Post I requested information on what kind of method ( glue, bonding agent) I could use to hold the ballast together having the track sitting on timber, can anybodey help?
Thanks , John
Thanks , John
I have used a 50-50 mixture of Titebond III and water sprayed onto the balast. It does hold the balast together but doesn’t breakup very easily when you want to dress up the roads. I’ll probably stick with the glue this year and see how it goes.
Rex
Rex, thanks a lot for the help, I assume when you say " to stick to with the glue this year" , you mean white glue?
Thanks , John
Titebond III is a waterproof wood glue. It is tan in color in liquid form. The key is the waterproof property when its cured. Regular wood glue will wash away while a waterproof wood glue will keep the balast together much longer.
Rex
