How to install a Circuitron remote mount tortoise switch machine and actuator
Nice job of juggling camera, tortoise, track and wiring. Have some questions for you; (1) you mentioned that you will be using only one Tortoise to activate the two Crossover switches-can you show us how? (2) Your cars all have Occupancy resistors for identification I understand, whose did you use? (3) The electrical paint for the resistor axles is hard to find, which brand and from whom did you purchase it? If you need a third hand for the camera lens I will volunteer or check out Logitec’s camera which will follow you anywhere and tape to the computer directly–a thought.
I sure many find this useful, but it is hard to watch in standard definition, with so much HD around. Plus some safety measures would be better, like holding things while you drill
