Hi how could i make some low buget grass? my layout is 4x8 HO… thanks Hobojim
Saw dust is the cheapest. Color with acrylics or dye. Ground foam costs a little, but goes a lone way. Static grass is about the same as foam, and looks OK without using the expensive applicator.
You might want to do a search on “making ground foam”. It is real easy to do![:P]
John T.
