how to put trackshon tires on a k-line engine
CAN SOME ONE HELP, I NEED TO PUT TRACTION TIRES ON A K-LINE K3799-09005 ALLEGHENY -TENDER ENGINE, HOW CAN I DO IT, THE DEALER WANTS OVER $100.OO TO PUT 4, TRACKSHON TIRES ON THE ENGINE, CAN SOMEONE DOWN LOAD ME A MANUAL,… OR PICTURE ON WHAT I MUST TAKE A PART TO PUT THESE TIRES ON, I DID ALL MY OUTER ENGINES WITH NO PROBLEMS, BUT THIS ONE IS A NEW ENGINE IN MY COLLECTION, AND IS A GRADE 10. I WILL PAY FOR A SERVICE MANUAL IF YOU DOWN LOAD ME A COPY. FROM YOU.PS IT HAS TWO SETS OF SIX WHEAL DRIVERS AND TWO MOTOR DRIVE,
ALL WHO ANSWER THANK SO MUCH. DROP ME A LINE AT ( PRR.GG.ONE@GMAIL.COM) I WOULD LIKE MY ANSWER SEND THERE, PS, HOW DO YOU START A HOME BASE TRAIN BIGNESS AT HOME BEING DISABLED AND FIXED FRIEND AND TERR TRENDS TRAINS, I WANT TO SELL ALSO,CAN ANY HELP. AIM IN SUSSEX COUNTY NEW JERSEY THAN YOU
To replace the traction tires on most steam engines you need to drop the side rods(not always easy), silver looking connecting rods, sometimes depending on make and model you may have to remove the motor unit, and then take off the old tires and replace with new tires. On diesel engines, usually you have to remove the plastic looking brake and shock assembly, then dismount the wheels from the truck assembly that houses the motors.
I don’t have a manual for your locomotive but typically replacing rubber traction tires on a steamer is not to difficult. Usually consists of removing the screw that holds the drive rod in place that is over the wheel and then stretching the rubber tire around the drive wheel. Jeweler picks are really helpful in pulling the rubber tire around the wheel. You can get a set of 4 picks of various shapes at Harbor Freight for around 3 dollars.
PS, typing in all capitol letters makes for difficult reading of your posting.
