How to remove the shell on a Proto 2000 Heritage 0-6-0
Need the procedure to remove the body to lube the motor & worm gear on my engine. Instructions that came with the engine DO NOT EXPLAIN HOW TO REMOVE THE BODY FROM THE FRAME. [:(]
The usual ways to disassemble don’t work. As is so often the case, instructions tell you to do it but don’t give you any hint as to how.
Any help would be appreciated.
Steam Train,
You asked for any help,so here it is,Remove the bottom screws at the gear plate,another screw down the smoke stack and another screw hidden under the electric connector,under the rear of the loco…Should do it…
Cheers,
Frank [:)]
