HOW TO REMOVE TRACK PINS FROM TUBULAR TRACK?
So, how does one go about removing the track pins from tubular track? best way? Best tools?
Thanks!
Use diagonal pliers or linemans pliers to grip the pin with the cutting edge, and use the folded webbing as a fulcrum to extract the pin straight out. You want to keep wiggling to a minimum to preserve the rail profile.
Pin Pull
If they’re really stuck tight, try prying the bottom of the rail open a bit with a flat screwdriver while you pull with the pliers. You can tighten the rail back up with needlenose pliers.
Postwar pins are solid and you can pull them with pliers. BUT from 1970 and beyond the pins are hollow so a little more care is needed. Penny’s suggestion is valid. Pry open the rail.
The rolled pins only lasted about 18 months-2 years 1970-1972 on O-27 track only, then MPC went back to solid pins… they have been solid ever since.
If you have to pull a hollow/rolled pin, just toss it and replace it with a regular solid pin when you place/re-place it.
They used hollow pins longer than 2 years so if your 027 track has brown ties be aware that the pins might be hollow.
I spread the rail with a screwdriver, push the tip of the pin down (toward the ground) to disengage it from the indentation, then reshape the rail. You can use long-nosed pliers or special pliers made for the job.
I use a pair of pincers that I inherited from my father. The jaws fit the web of O27 track perfectly, and one of the handles ends in a screwdriver blade. He bought them in Japan when we lived there in 1952, so there’s a bit of nostalgia every time I use them.
Thanks everyone for the help!!
