Greetings!
Do you have any old boxcars just sitting around that you don’t know what to do with? Here’s a simple idea of turning a retired wood boxcar into a useful trackside structure - just like the railroads used to do.
(Click pictures to enlarge them)
Materials needed: (Either wood or styrene can be used)
(1) Shell - Accurail 40’ boxcar, with ridge walk and brake wheel removed
(1) Floor - 1-1/8" x 5-1/2" x 1/16" thick sheeting
(4) Floor standoffs - 1-1/8" x 1/2" x 1/16" thick sheeting
(1) Roof substrate - (2) pieces of 5-13/16" x 5/8" x 1/32" sheeting
(2) Fascia boards (long) - 2 x 8 dimensional lumber x 5-7/8" long
(4) Fascia boards (short) - 2 x 8 dimensional lumber x 1-3/8" long
Roofing: Silcone Carbide sandpaper: 320 grit (black)
X-acto blade: #11
DISCLAIMER: I got the idea from an American Model Builders boxcar shed and depot kit that put together last year. I used a 40’ Accurail boxcar for my project. Obviously, dimensions will vary in the type of car used and between manufacturers. Sorry for the lack of pictures to the tutorial. I thought of it AFTER I had put everything together. [:(]
Construction
- Remove center ridge walk from top of box car shell. Remove brake wheel from box car end, if desired.
Spread boxcar shell apart with your fingers. Press floor piece up inside of shell until it butts up along inside ridge, where the frame would rest. A proper fit should yield a 1/16" between the bottom of flooring and the bottom of the shell.
Glue the (4) floor standoffs to bottom side of flooring, as shown. The bottom of the standoff should now be even with the botto
