Last night I connected my Powercab to the NCE USB interface after downloading the driver and JMRI but I am not sure that everything is communicating.
I thought there is a little LED on the interface but I do not see anything So how do I know when locomotive accepts a CV change will it move like a program change from the powerca?
If JMRI can’t “talk” to your command station, or otherwise doesn’t get a response that the write completed successfully, JMRI will tell you that the attempt failed and give you an error code:
I use Digitrax but my initial check to see if JMRI is actually communicating with the Command station is to simply open a throttle and cycle track power on and off. If that works, it is connected.
Joe, I’ll be using JMRI for the first time, in a couple days, setting up the address, head light/reverse light, with the Rule 17, and all the ditch light functions, all Digitrax, on a an Amtrak P42 project. All of this for the first time.
