Aw, it was inevitable, wasn’t it?
I second your toast complaint. I like my toast almost burnt, but my damned toster will only do slighty-warm.
David
That’s because you’re using that low-end toaster you bought at Toasters-R-Us. See, if you upgrade to the high-end wireless toaster system, you wouldn’t have these problems.
Besides, the high-end toasters allow you to operate like a real chef. Run your toast, not your toaster!
Is your toaster DCC or DC? Is it far from the power source? Perhaps the solution for weak toast is to run feeder wires to it. Ken
I don’t get toast anymore,my toaster is toasted.
I use a 10 gauge bus with 12 gauge feeders to each toaster. I can do 16 slices at a time.
Enjoy
Paul
And another thing - when the “toast-is-done” buzzer went off, my Toastmaster sounded more like a Sunbeam - not prototypical!
…at least the smoke was realistic.
Is there a full moon?
The question is, do you want to operate more than two toasters at the same time?
My local hobby shop doesn’t even stock toasters!!!
And the owner doesn’t even eat toast.
I get all my toast cheaper on the internet![:P]
And THAT is why all the LTS are going out of business.
Look at the price on this toaster on eBay:
$300? Is this guy nuts? It’s not even DCC-ready!
Toasters are way to expensive and complicated. Give me the plain old bread anytime.
Besides, last time I put bread in mine, it let the magic smoke out of the bread. [xx(]
Was wondering, do you like margine or real butter on your toast???
Me n the grandkids like the real thing better
[#offtopic][#oops]Way to fix toaster. First start by cutting the plug end off. Split the wire down the middle seperating the ground and hot. Then remove about 3/8" of insulation,exposing the copper wire. Next load toast ,dont forget to lock the toast in place (push down the lever). Finally walk over to your elect panel. Remove the six screws holding the cover in place. Finally there are several large wires at the top carefully touch wires to either the lugs or exposed cable. Caution this may result in burnt toast and a permanent perm or Afro. Also would advise having an ambulance on stand by just in case you need a little help. Dont worry about the toaster because it is now toasted. [#oops]
[#offtopic] Sorry hit this button by mistake
And be sure that the toaster doesn’t exceed the current capacity and capability of the decoder, or your decoder will be toasted. Butter anyone?
For the guy that needs the ambulance, I got it, but while I am waiting, Apple jelly is my favorite!
Apple butter isn’t bad either.
Get some good homemade jelly for all this toast talk. And who would have the nerve to buy a toaster off of eBay?? Are u guys crazy? eBays toaster prices are outragous, and you have got to support your LTS with all your toasting needs, not eBay. Jeez, and I thought you guys were smart…
-beegle55
I am thinking that Hamilton Beach has some of the better toasters out there. Check it out:http://www.todaysconcept.com/hamilton-beach-toasters.html?gcid=s13563x001&keyword="hamilton+beach+toasters"&MATCHTYPE=search&gclid=CMz75aiW_4sCFRGCGgodnSYZzA
