I figure I have a month or two to figure this one out. I need to get DCC with sound into a Hogwart’s Express. If I can get it all in, insulate the frame, stick a speaker in the tender, I’m going to have as jetrock put it, an expensive toy.
But what if I were to treat this like a 38 Ford and yank everything but the the body and chassis. What would it take to make this “toy” ride along beside the new Broadways with pride ( and take them by 3 seconds in the 1/4 mile?)
I’ve squeezed a soundtraxx dsd 100-lc decoder in a diesel, you can also get them for steam about $80 plus a speaker and your away (apart fron the rest of the DCC of course!!
I would check out Soundtraxx and Loy’s Toys. Fred at Loy’s is very knowledgable and might be able to tell you exactly what you need. They also have quite an extensive catalogue with pictures and details.
If you plan to replace the mechanism, you’re in for a lot of work. There’s a company named Comet over here that offers new etched brass frames for Bachmann locos, so you’d need those, a motor, wheels, gears, etc - to the best of my knowledge it’s not possible to buy a complete kit. I would say stick with the Bachmann chassis - they’re pretty good when properly set up, the only problems I’ve had have been out-of-gauge wheelsets and incorrect quartering, both of which make it “lumpy” - if yours runs smoothly then there’s no problems. The secret to these chassis is to oil the motor bearings and put a dab of grease in the gearing, they run very nicely after this has been done. A Bachmann loco that’s had a few hours break-in and has been lubed is a beautiful runner and will creep along very nicely.
If you do decide you want to rebuild the loco on a new chassis, www.mainlytrains.com should be able to help you, they do mail-order and are thought well of over here. email them and explain the situation, they should be able to help. They also have loads of detail parts that you might be interested in - you could super-detail the loco, repaint the tender (the huge crest on the Bachmann model is nothing like the one in the film) and model 5972 “Oulton Hall” in its film guise as “Hogwarts Castle”. Hope this is of help!
P.S. one small point. The Bachmann model is a “Modified Hall” - a variant of the “Hall” class. I’m not sure whether the real 5972 is a normal Hall or the Modified version though! www.railwayscene.co.uk have photos that might be of use to you in detailing the loco. Good luck!
It might be an “expensive toy”, but it would be a cool one. The analogy to the '38 Ford is a good one. I’ll second Fergie’s suggestion to contact Loy’s Toys. They’re both very knowledgeable and very helpful. Keep us informed on your progress.
Have Fun,
Tom Watkins
Not familier with the hogwarts express,but have you looked into the possibility of finding a mechanism that the hogwarts shell could fit on.Maybe a BLI,orBachmann Spectrum ?
Hi Chip: Bachmann will not have a ten wheeler chassis to fit your engine. your engine is a Great Western Railway Hall-class ten-wheeler called ‘Olton Hall’ painted red to match the one in the movie and it is OO scale. Backmann makes HO scale. Your only hope is to get a Hall class ten wheeler from an importer of British engines or via internet and do a body swap yourself. It will not be cheap.
]i]The reason I am asking is that my autistic son wants DCC with sound. He will not be talked into gettting a differnt locomotive. I wanted t be sure I was not throwing money at something that would breakdown quickly.
How would you rate the quality of the Hogwarts Locomotive? Is it a cheap toy or something better?
A reply:
Hello Chip. I collect OO models made by Bachmann-Branchline, and a brand new Hall model is expected this month. The 3 models are dark green. The “Blue Riband” range of locos are DCC ready ( or at least DCC friendly). The problem could be the lack of space in the boiler, but the tender collect power, so you can mount the sound kit there. They are a little bit expensive now because the weakness of the dollar against european currencys. Best regards from Uruguay-South America, Gastón[/i]
Well, I put a dcc decoder in my Hogwarts Express. I put it in the tender. There’s plenty of room in there for a speaker, so I don’t see why you couldn’t put sound in there as well.
You do need to run wires from the loco to the tender, but it can be done fairly easily.
Hi Chip: why not convert your existing Hogswort to DCC and add a Soundtrax decoder? As for quality of the engine, I bought one for my son 2 years ago to run on his layout and with some minor modifications and diligent wheel and track cleaning with good lubrication, it has run flawlesly. It needs wieght in the tender and over the front truck. It even can be seen running occasionaly on my layout pulling soom CP and CN boxcars.
I recommend Litchfield Station for DCC products. E-mail Bruce–he’s very helpful. http://www.litchfieldstation.com/ Perhaps he’s done it already or could recommend a decoder.
IF your ‘Hogswart’ is British 00 gage it will not run properly on NMRA HO track.
Our HO Hogswarts’ are continually breaking down with contiuous running at our club’s annual show
COCLUSION: 1. This Bachmann product is made for the ‘toy’ market, not modeler’s, 2. Will never run right on non 00 gage track. 3. would be a poor investment to convert to sound.
If you still want a ‘HOGSWART EXP.’ better to buy a new one and have a DCC sound unit installed,
That said, Bachmann’s SPECTRUM LINE steam have gotten much higher marks - particularly the 2-8-0 and 2-10-0.
I have no doubt that you are correct, but no matter how you explained that to a 7 year-old autistic kid, your not going to convince him that there is a better train thatn the Hogwarts. Bachman no longer has the Hogwarts contract. It looksd like I have 4 choices.
Put a DCC with sound in the one I have. I buy up a few Hogwarts junkers and keep it running as long as I can.
Buy a British 10 wheeler and put the Hogwarst body on it.
Get an Markle 3 wheel AC and gut it. Put a DC motor and new trucks.
4 Use the Hogwarts Body and build it from scratch.
I think, I’m leaning toward #1, but I’m open to better ideas.
Chip it’s a lon shot but if you stick with option one check out your local Toys r us they carry or carried the hogwarts sets up here in Canada TRU sold them off real cheap like $60 CDN so it may be worth a shot. TB
How about just not putting DCC in it, and getting the kid a Soundtraxx sound-effects generator so he can make all the bell, whistle and steam engine noises he wants?
Failing that–try installing DCC in a similar but cheap and expendable engine (like your fake FEF) to get the hang of it, and so if things don’t work right you won’t be out your Hogwarts Express engine.
Don Gibson: British OO gauge is the same as HO gauge in the States (16.5mm)–the same Peco switches that Brits buy for their OO layouts is sold in the US for HO railroads, and it works just fine. Obviously clearances might not be the same, but most Brit stuff is smaller than its US counterpart.
As I said before, I’d advise sticking with the chassis it came with, assuming it’s the same as the one they fit on their British “Modified Hall” - these are very well-regarded over here, there are a lot of large, finescale layouts that use large numbers of Bachmann steamers with varying amounts of added detail, they work very well. The only problems I’ve found with these chassis are with wheel quartering and gauge, though these can easily be fixed. Keep it properly lubed and the wheels clean and it should run for years.
If you do have a major mechanical failure it’s possible to buy the chassis seperately for most British Bachmann locos - www.ehattons.com/Stock.asp?SID=9691 would be the part you need in this case, though when shipping is included it might be cheaper to buy another loco…Hope this is of help!
Talk to me about Soundtraxx. I went to their website and all I could find out about was DCC decoders. They are out of production of their sound systems–working on an upgrade with no release date. They have no description, so I can’t get an idea of what they do.
SpaceMouse: Do you have a local hobby shop? I just note that you tend to order everything via the Internet–but sometimes there is no substitute for going to a hobby shop and seeing & buying stuff in person–and being able to handle something before you plunk down the cash!
