Per the FRA’s 2005 Annual Safety Report, Dec 18, 2006, with the statistics from 2005, which are the last available published so far.
Page 71, Table 5-9, Train Accident by specific cause and type.
Shoving movement, Absence of Man,
(no point protection, or shoving blind)
Resulted in 146 accidents, or 4.2% of all reportable human factor accidents.
This caused 45 collisions, and 57 derailments and 44 “other” meaning hitting a structure, bumper, or some object.
5 of these occurred on main line track, 117 on yard tracks, and 24 on “other” tracks, such as service tracks, RIP tracks and such.
Total reportable dollar value of equipment and material destroyed,
$6,404, 659.00
Total fatalities, 0, non fatal injuries, 2.
The two other “human factor failure” causing more dollar damage was failure to comply with automatic block signal or interlocking signal displaying a stop indication…$16,173,496.00…resulting in 4 deaths and 8 non fatal injuries.
Followed by
Switch Improperly Lined…200 incidents, or 5.8% of accidents caused, resulting in $10,005,718.00 damages, 19 collisions, 151 derailments, 9 occurred on main line, 155 on yard track, and 26 “others”.
Total of 9 fatalities and 305 non fatal injuries.
So, you have running past a signal displaying stop, followed by improperly lined switches, then blind shoves as the three major types of accidents causing death and injuries, with the largest loss in dollar amounts.
Each railroad addresses blind shove in their operating rules, and most follow the FRA recommendations.
These recommendations allow shoving half the capacity of yard tracks without a man riding point, as long as point protection is provided in one of the following manners.
A crew member must be in position to have constant visual contact with the leading end of the move
