I am now the owner of a train set but I know nothing about them. Wondering if anyone could shed any light on the situation. The engine is a Lionel 8021 as read on the bottom. It is silver with a red nose. Amtrak on the side with the number 8664.
It is a 6-8664, made in 1776-77 by MPC (“Model Products Corporation”), the General Mills company that succeeded the original Lionel. It is an undersized model of an Alco FA-2.
The number 8021 is puzzling. A Lionel part number, such as a locomotive frame, often included the model number that it was first used on; but the 8021 was a B unit. Did you see that number on the A unit?
Is this your set?
Bob,
I just love slips of the finger. I know you meant to type 1976, but your date would truely make it part of a Heritage Fleet. [;)]
Northwoods Flyer
Greg
If it is, that is a great set. I know it is simple/plain by today’s standards but my mom bought me that set in 1977 and I still have it. Still runs very well and it has a classic Lionel toy train look to it.
If the original poster has this new-in-box, obviously a good lube and careful running in will be necessary. You’ve come to the right place to get advice.
Thank you so much for your responses. My train does look like one in the picture here. We have the cars too and a lot of track. That’s exciting!
Welcome to the wonderful world of O Gauge TMich! Doesn’t matter how you got here, just get ready to enjoy the ride!
You’ll get some great advice here! And your Christmas Tree will be all the better!
Welcome to the forum that’s a nice set even in used condition you need help with it we are here to help just ask most will try to help and sometimes it may even get a little confusing. ( we don’t mean to but there might be more than 1 way to fix something lol)
Welcome,
I agree with Bob. 1976 -77 MPC # 8664 A uint. A nice addition to the set would be the # 8667 B unit. Now just lay some track and have some fun. [;)]
I also have an lionel 8864 but have a problem that I cannot solve. The engine derails constantly. I have replaced the engine because of other issues but have had the same problem with both engines. There are no obvious defects. I have run the engine on multiple tracks with the same results.
I’m having a similar issue with an 8031 CN GP7. It derails at the same spot on a curve. I think it has something to do with the pick-up roller on the dummy truck dropping between the O31 rails. Running the loco the other way around doesn’t fix the problem. Maybe your issue is similar?
Note: I have an A-B pair of Santa Fe Alcos (8861-8862) of similar vintage to your Amtrak loco, yet they make it past the spot that’s derailing the Geep.
Try taking the cab off and pushing the spring clips a LITTLE farther down. That would put more pressure on the truck. New springs could be another option.
Thanks. I have tried pushing the springs down with no luck. I will try a stiffer spring.
I have found on other locomotives that when derailing around curves, the track was not secured at that point to the board and lifts slightly derailing the locomotive.
Success ! I removed the original springs and replaced them with springs that were about 2X the spring force of the originals, made adjustments (least spring force worked best) and bingo ! All is well.
