i need an answer about a train table construction.....
does it matter if u paint ur plywood and roadbed stufs with latex stuff or not? and wats the best thing for gluing homasote to wood?
Painting or sealing plywood is important if your layout is going to be in a damp area, such as a basement. Even with a dehumidifier, the humidity can fluctuate and cause warping as the wood absorbs and releases it.
From a scenery point of view, the plywood should be covered.
Most wood glues will work well with wood to homosote joints. I use Elmer’s Carpenter’s Wood Glue diluted about 25% with water to help it absorb into the homosote. Too much water will warp the homosote. For pine joints, like the layout framework, use the glue full strength.
Some people do nothing and have no problems and some go to the extreme sealing all wood with varnish or shellac to prevent mositure problems. I live in Chicago where the temperature outside ranges form 27 below (one time) to over 100 and have a damp basement where humidity ranges from 90+% down to virtually none. I have never sealed wood and never had a problem. Others have so go figure. I use wood glue to hold homasote to plywood and never had a problem (yet!). Yes you can paint wood with latex. That is what it is designed for as long as it is exterior paint.
