I need about a gallon of plastic water has anyone a “cheap” sorce for this stuff?
If it will be too expensive to make my river and moat deep I’ll have to do with shallow water but then I’m going to have to scale back on the stuff under the surface.
Thanks, Jess.
There was some instant water that came out a while back, but no one could figure out what to add.
Can you give more of an idea what you plan to do with it? If you are trying to make it deep and clear and cheap I’m drawing a blank.
My wife used resin on an multi-media sculpture where an egg was about 2-3 inches under the surface. It worked pretty well, but if I remember it was a slightly yellow color. Still that might not be out of place on a moat and especially in a wooded area where tannic acid would leach into the ground.
A.C. Moore, the art supply place, has a weekly coupon which is good for 40% off on any one item. Check out www.acmoore.com, and locate the closest store to you. Once you find the store, there will be a link to the coupon. You can use that to buy a big bottle of Envirotex. If that’s not enough, do it again next week.
