Hello everyone. I am having a little problem with train-sim.com. After I download the file I cant unzip the file. How do you do it?
IF you have XP, you can use the native unzipping program, if not use winzip - there is a free version.
In XP, you right click on the file. The command is extract all I believe. Be sure you read the readme file before you do and make sure you are unzipping it in the right place (some want to be put in a temp file that then installs to MSTS, others want to be unzipped into different locations).
The free version of winzip can be found through a search on any search engine. Works the same way.
