I really need some ideas!!!!
I have MS and the only thing that brings me joy is running my trains. Problem is there in the basement and I can’t use my legs very well. Getting into the basement no problem, getting out big problem. I haven’t ran my trains in 4 years do to this. But I can’t help but think there is a way around this. I can lower the plat form to reach what I need to, but finding a way back up the stairs has me stumped. I think I can just muscle my way up the steeps but looking for possibley a better way. I can’t be the only one like this. Just looking fore some ideas. We are smart and creative people someone has to have an idea for me?
Have you thought of a chairlift? They are advertised on TV fairly often.
My mother in law used one from main floor to upper.
They are pricey if insurance will not help.
Dave
That is something I thought about but $$$$$ Y KNOW! i keep thinking I’m overlooking a simpler way!
I agree with the others mount a chair lift on the stairs if the layout must remain in the basement . Cost may be a problem. They appear to be $2,000 plus installation.
https://www.google.com/search?q=chair+lift+for+stairs&rlz=1C1WZPD_enUS396&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiXtI-Cn5HSAhVGzmMKHchsD2AQ_AUICSgC&biw=1607&bih=875
Perhaps have the layout moved or build a new layout upstairs.
OOPs, deleted, all ready suggested on the post before me. [swg] About moving it all upstairs.
Mike.
Do you have insurance that could pay all or part of the cost?
Just thinking outloud; to move between two levels you need stairs/ladder or ramp.Ladder or ramp woun’t work,brings us back to stairs.To just ‘‘man up’’ and drag yourself up/down sounds like a good way to get hurt.
Are there somekind of state/fed. programs to help? perhaps a preused unit? [chairlift]
It may be in your best interest, to move layout.Rebuild one that is costom built to your needs.
You can allways ‘‘give up’’ tomorrow,as for now keep trying
I have seen some small personal elevators in some houses I have inspected, but I’m sure these are even more expensive than the stair lift. I have seen 1 elevator unit that was retro-fitted into an excisting home.
I’m still thinking that moving the layout, or rebuilding it on the upper level would be the best.
Mike.
I have a friend who moved her mother(80) into her house. The bedrooms are on the second floor. Medicare and it’s add-on virtually paid for the lift and installation. The dealer even did all of the paperwork. If the OP is on some kind of disability or assistance, this should be a ‘no brainer’…
Jim
Contact charities. Lots of companies that renovate houses need to remove the chair lifts when the property is remodelled for the new (not disabled) tennant/owner. I know that here in Florida Habitat for Humanity takes these as donations and will install them for people who need them close to no cost.
-Kevin
I have several friends with MS. Some have had little progression and others have faired poorly. I am sorry for your illness.
Assuming it’s not covered by Medicare, how about a Go Fund Me page? You might not want to ask for help, but if they can raise $8,000 for a dog (and they do), why not you? If it helps you enjoy life, people can give freely or not. Facebook could be a help here, a story in the local paper or TV channel would also give you a jump start. If you a veteran that might help. Help from you church, just to spread the word on Facebook.
I have no idea how expensive an elevator is, but it would give you flexibility in the future. Plan for routine maintenance expense.
I installed a stair lift in my old house for my ex mother-in-law to be able to go upstairs. Installing them is actually pretty easy, you provide measurements and the track sections come pre-cut to length, and it’s just a few lag bolts into the stairs to mount them. The mechanicals are all in the chair and base, whioch sits on the track. The one I installed, it just had some contacts top and bottom connectedi with some two wire zip cord, and then a small wall wart at the top (or bottom) which served to charge the battery in the chair when it was at either end. The chair ran on a small sealed lead acid battery, and it had enough juice for several trips even if the power was out.
So what you need is a friend who is at least slightly handy with mechanical things to install it for you. There is often help available to reduce your cost for the unit, as well.
SLK
I have a friend who has this. He is telling me that his Doctors are telling him that there is a medicine that is due out in a few months that they believe will cure MS. If that happens I will pass along the info. Do me a favor and send me a PM and I will pass it along then.
YGW
