I build a fair number of almost-prototypically accurate models of Delaware & Hudson locomotives (steam and Diesel) and cabooses, all in HO. Most of the time, I weather the rolling stock with Bragdon chalks after I liberally coat the model with Testors Dullcote.
Every time I’ve used Dullcote, I have to be alert to remove tiny particles that look like airborne dust. I use a Paasche spray hood and paint in an upstairs bedroom with good air circulation. I use a single action internal mix brush and I’ve changed to a new bottle of Dullcote, with the same result - little tiny fibers attached to the finished model. Quick action with a pair of tweezers solves it but that’s a lot of work.
I decided to try one of the acrylic clear flat “paints.” I bought Testors Model Master acryl clear flat coat and their $6.00 recommended thinner. Today was the first “go” at it and I found the results to be exemplary. NO dust particles or tiny fibers. And the finish looks every bit as good as with Dullcote, with the added advantage that you can handle the model within a half-hour of coating it. Like most acrylics, I won’t really be hardened for a day or so but I was able to assemble my latest caboose model and install all the plastic window inserts. So far, I highly recommend Model Master clear flat paint.
