i would like some input on this kit please
Hello I have on order a JL innovative design it’s the Fryxell feed&seed kit # 361-181. This is my first kit of this type is there anything I should know/have before I start this kit ? What kind of glue should be used ? Thanks Frank
I don’t have that particular kit, but I did build the HO scale Schmiege’s Little Dutch Store. They are laser cut wood. You need a lot of patience, a very sharp X-acto knife, good corner clamps or an area where you can keep the corners square while the glue sets, and plain wood glue such as Elmer’s yellow carpenter’s glue.
Nothing is painted, so you have to do that, too. I added a lot of interior bracing cut out of wood strips to keep the walls from warping, because I used the cheap water-based acrylic craft paints from Wal-mart. You have to provide your own strips if you want to add the bracing. Spring clothes pins make good clamps to hold pieces while the glue dries, and a NWSL Chopper is very handy to have on hand.
These kits come with very detailed instructions and suggestions on what to use, so be sure to read and follow thier guidelines. Very good kits.
Painting both sides of the wood can help reduce warping. Try not to get any glue on the exterior because the paint/stain won’t soak in and you’ll have shiny spots.
Hello thanks guys for the info. The kit should be here next week sometime. I am looking forward to building it. How well do the parts come out of the spur ? Are they broken easily? Thanks Frank
I have not done this kit but most laser types are the same basically. Use a sharp #11 blade as mentioned earlier. thke your time !!! Identfy all of the parts and read the instructions. Most manufacturers know the right order for assembly. Pre paint as much as possible. I have done a lot of laser kits by different makers and they have turned out well. Have fun.
Dave
Here are some hints. There are variations on these ideas and you will probably find those which suit your more. You also learn by doing. This can be a tough way to learn about building wood kits without starting will small basic wood kits. Put the link in your Favorites folder as the site has a lot of useful information.
http://www.gatewaynmra.org/articles/sheahan-wood.htm
Be advised, some people are kind of religious. Their way is the only way. Find out what works for you.
