I have a couple of walls on the sprue but no clue which structure they are. A search on walthers resulted in nothing and google never identified it either.
They are 2 story brick walls, arched windows on what I believe is the front.
700 is not a number which I can seem to trace as assigned to any manufacturer in the Walthers catalog system, but 3032 is the Walthers Crown Paint and Hardware structure kit which might be made for them by Heljan which could account for that 700. I too have acquired orphaned Walthers sprues and find that the last numbers are the useful ones, not the prefix
I’m not certain, but I believe the first three digits are Walther’s manufacturer identification numbers. If you scan thru Walther’s online catalog, you might be able to spot the numbers and confirm this.
Apparently this is the kit that I have. Thank you very much. Ill have to remember that the last numbers are the important ones. I am missing the back wall but I can over come that with sheet styrene in brick pattern or just use black styrene and make it a background building.
I do know that Walthers will have runs of parts sprues and put them in a box even if the structure only calls for one or two parts off that sprue. Ive probably got 8 rooftop detail sprues from various kits that only needed an ac unit off of it. Lol
