If I had only known:
Five years ago I began construction of my Garden Railroad (the Rosebud Falls Scenic Railways, a fictional line loosely based on The Denver and Rio Grand Western.) As part of the GRR, my wife required a Koi pond. Having absolutely no experience in pond construction, I visited numerous pond web sites and decided that it should not be that difficult to construct. A couple of planning visits to my local pond supply store confirmed that the task of pond construction was not all that complicated. They supplied me with the following diagram describing how to plumb the pond.
As the drawing shows, I placed the vertical down pipe to the bottom drain very near the side of the pond. As a resident of southern California, I am very well aware that on occasion the ground around here has a tendency to shake. I had not allowed for any flex in the piping to the bottom drain. A few weeks back (towards the end of August 08) we had a quick little jolt by Mother Nature. Shortly after I noticed that I was adding a lot more water to the pond than normal. The pond holds a little under 2,000 gallons, and normal water replacement from evaporation, splash from the waterfall, and dogs drinking from the pond, is about 20~25 gallons per week. Over the last few weeks I’ve been adding 30~40 gallons of fresh water per day. Over the past weekend I decided to pump down the water level in the pond to find where the leak is located. As the water level reached the level of the top of the vertical pipe I heard the unmistakable sound of air sucking into the three-inch pipe, the pump lost its prime, and water quit flowing. Now I have the task of digging out the offending pipe and repairing it. Before digging out the pipe, I’ll be puling up a 30(+) foot long bridge, and about 30 feet of track, as well as a few buildings, cows, pigs, horses, hobos and such and a bunch of plants that the wife recently acquired for the RR.
Lesso
Whoops.
NO! It is not whoops. It is OOOPS! whoops implies having fun.
Back in my days in the Army we would have quoted the rule of 7-P’s, profecient prior planning prevents plainy poor performance.
I was trying to be the ever optimist.
Tom,
why don’t you send this in to Marc Horovitz (mhorovitz@gardenrailways.com) with the drawing and a photo of your pond to be published in the magazine?
Tom,
Bummer!
Does the pond have a liner or did you do concrete? Either way the drain at the bottom is a major pain with external plumbing. Could you run the drain line inside the pond and just cap off the bottom exit? I know it doesn’t look as good in a swimming pool but in a Koi pond I’ll bet you wouldn’t see much of a black pipe. It would save a lot of digging and disruption. Just a thought…
Rex
Rex: The pond is formed with a liner. However, there is a layer of mortared stone on top of the liner. I plan on ripping down just enough stone to pull the liner off of the offending joint. When I say “off the offending joint”, that is exactly what I mean.
Here is an overall pix of the pond.
The offending joint is under the corner flat “ring stone” just inches away from the light house.
The corner ring stone sits on the rubber pond liner which is directly on top of the three inch ninety degree “sweep” where the pipe turns down and is in contact with the pond liner all the way to the very bottom of the pond. I’m going to start the repairs (or rather the demolition to begin the repairs) on Wednesday. I’ll post a few picks of the demolition and repairs, if you guys are interested.
Tom,
That does sound like a major pain. I for one would like to see pictures of how you work it out. I’ve got a rubber lined stream feeding a to-be-built flume for my grist mill. The stream is operated by a small waterfall pump located in a basin below the helix which means piping like you have. I’m at the plumbing stage so would love to learn from your experience and hopefully not make the same mistake.
If you had it to do over again what would you change?
Rex
wow that sure stinks! We dont have many quakes in my area but the information is very useful to me! My sisters fiancee just gave me a pump he was going to use to make a pond/waterfall with in his frontyard because my sister didnt approve so he gave it to me to build one in my backyard :slight_smile:
Say Tom,
Is it really necessary to have a center drain/pump draw line in the pond anyway ?
I designed my two main ponds with only wide mouth skimmers for water return, and for recirculation of the water, the same as you would use on an above ground pool. Seems to be working just fine.
That way you eliminate the problem line all together. I will do any future, IF necessary, bottom cleaning, with a regular pool vacuum and sweeper head, with it connected to the skimmer inlet.
As for draining, if ever necessary again, I already have a small submersible sump pump, that I picked up from the Evil-Bay for less than 30 bucks. It has always worked fine in times past during the initial construction stages.
I have a sump pond, to draw water from initially, that holds about 300 gallons, and two main ponds, about 10 to 12 foot in diameter, that individually hold probably between 10 to 12 hundred gallons each.
All so far seems to work well, there is a stream flowing from the ponds back to the sump pond, I also have two fountains at present, and do plan on designing two water falls into the one pond.
It’s all serviced with a 1.5HP self priming pump and a 16 inch sand filter, all Hayward Pool supplies.
Byron
Tom,
First, the pond guys should have told you to use flexible pipe. Even here in DE when they built my pond they did everything with flex tubing, even the 3 inch stuff.
My pond guy sez he’s only had problems with putting a hole in a liner to make a bottom drain; thus uses only the skimmer box, even though the company whose line he uses makes a bottom drain fitting.
I have a problem not having a bottom drain in that the fish poo and dead algae really just coat the bottom. I’d like to figure out a way to do some sort of submersible pump in the deepest part of the pond; one that would move the deleterus yet not suck up the fish!
My pond is about 22 feet wide X 40 feet long X 3.5 feet deep at the deepest, then there is the new 27 foot X 3 foot X 1.5 foot river running from the falls to the pond. The pond guy figures we have between 16,500 to 17,500 gallons in it.
Dunno as I’d do that again, costs a fortune in upkeep! Also costs another fortune in fish to feed the @#$%$#^%$*& Blue Heron. Can’t put net over cause have to get in to trim lillies, etc.
I second Empire II Line’s idea of getting rid of the bottom drain. I put in a preformed liner for a Koi pond and use holes through the liner near the top and above the water line for in and out. This was going to be camouflaged by flagstones but haven’t got there yet.
SWMBO conned me into cleaning the bottom ONCE! If your filter really does its job, the bottom just takes on a ‘natural’ appearance. She thinks it looks okay, now.
Having everything that can fail above ground or IN the pond sure makes maintenance easier.
Art
I’ll try to answer all the questions you guys have asked.
Rex: “what would you change?”: When I built the pond, the bottom drain pipe runs about 18~20 inches under the bottom of the pond to the very edge of the pond and then turns vertical to join the main run to the pump. The vertical pipe is actually place inside the hole for the pond and covered by the liner with water on “2 ½ sides” of the pipe. The change I would suggest is to run the horizontal pipe from the drain several feet away from the pond before turning vertical. The problem I have is that the vertical pipe has been pulled out of the joint at the ninety degree sweep.
Byron: Having both the “leaf skimmer” and the bottom drain make for a much cleaner pond. The leaf skimmer removes all the floating debris and the bottom drain removes the sinking debris i.e. fish droppings and dead plant debris. Both of these drains join into a single pipe prior to the leaf catcher. The skimmer actually catches the leaves but the leaf catcher catches the plant stems and parts that sink to the bottom of the pond. A neighbor just a few doors down (so he has the same “micro-climate”) has a pond roughly the same size and depth. He elected to not install a bottom drain. Routine maintenance of the pond filter is about the same 3~5 minutes each week for both of us. However, he spends about an hour each month cleaning the bottom of his pond with a shop-vac, which I do not do. It takes about three weeks for his pond to “cloud up” such that he can no longer see the bottom.
Pool vacs attached to the leaf skimmer of the swimming pool do very well as that is a totally closed airtight system. A skimmer for pond use is not airtight, by it’s very nature, and a pool vac will not work on a pond skimmer. Been there, tried that, and failed.
Capt Bob: They did tell me to run the pipe a few feet away from the pond before turning up. They did not
Got the fish, plants and water out of the pond today.
http://s269.photobucket.com/albums/jj50/tltrigg/Pond%20Repairs/?albumview=slideshow
