Hi,
My friend has a problem with IM ES44DC. He tried to program decoder to have a loco in reverse so he set up CV29=35. Unfortunatelly, the model doesn’t run after it. The sound starts but engine doesn’t respond to any order. I found a manual for soundtraxx decoders and told him that he should enter CV30=2 or CV8=8 to reset the decoder. He claims that it doesn’t help.
Are these values are right for resetting a decoder in IM Gevo?
Any other idea? How to set up CV for reversing a direction ?
Arek
Arek.
Who makes the decoder? Could it be a Digitrax decoder? What is is the address? 35 in CV29 would require a 4 digit address. Make sure that CV19 is 0. Also hit F6 twice if it is a QSI decoder that is in shut down mode.
Pete
The decoder in IM Gevo is Soundtraxx Sound decoder.
Luckily, we managed to fix the problem. But, it was very strange. I have never seen the decoder which had problems like this. I have programmed many different decoders and I have never had any problems with changing direction in CV29.
The decoder should respond on address 3 after reset. It never happened. We tried both - programming on a program track and a main track (DCC system is Prodigy Advanced). We were able to program decoder (the model was moving a bit after each CV programing). We programmed CV29 back to value 6, CV 1 to value and we still couldn’t run the model. It didn’t respond on any address.
After this I was trying to find a solution in the internet and my frustrated friend was trying to find the address which loco could respond on. He started from 1 to 200, after it he tried 9999 and… 0
Bingo ! Loco respondedon address 0. Then we programmed CV29 to 6 for address 0 on main track and CV1 to 3. Everything was ok. Finally we changed CV29 for 7. Problem solved !
My friend has a model which respond for address 3 and runs in reverse. It should be a simple operation. Insted of fe seconds we we speny a few hour
If anyone will have similiar problem - try address 0
I have not run into this problem with a Tsunami.
One thing about doing a reset on the Tsunami’s. After you have entered the reset numbers you need to remove the power to the unit or the reset will not be completed.
I thought it was likely related to an address pb. It has happened to me several times. When moving to a 4 digit address, using a programming booster and service mode is the best way. Make sure you can check the key CVs after programming.
This is what I use:
http://www.soundtraxx.com/access/ptb100.php
Whether with Decoder Pro or the Cabs.
Richard
