Do a Google for “railroad maps”. There’s a bunch of sites. Library of Congress has historic maps. If you go to a railroads home page.(CP, UP, CSX) I’m sure they all have operation maps.
This is my idea. I would like to do a layout integrating Rte 66 into it. I need to find out which RR ran along Rte. 66 back in the 50’s and 60’s. Does that make more since?
With that much territory to cover even in a condensed version you had better have three double car garages hooked together for the space that you will need.
But GOOD LUCK to you. It is a great part of railroad history.
Thanks, I think I going to just do the towns in the song that run along a RR. I was going to do it in HO scale but your right that is alot territory to cover may have to go to N scale.
lucky you ! one of the other members of this forum has done a lot of research of the Arizona section of ATSF’s line near route 66 , you can find it here …
That’s a lot of towns…and they may not be served by the same railroads, if at all. Starting and ending a layout in major cities several thousand miles apart, and stopping in several medium-sized ones, makes anything like prototypical operation kind of difficult: remember, Los Angeles to Chicago was a trip that took two days on the fastest train (the Super Chief) and far longer for a freight train.
Remember, a mile in N scale is around thirty feet, and the distance from Los Angeles to Chicago is around 2000 miles. Modeling the whole thing in N scale would take around twelve miles. How big of a layout did you have in mind?
Although, this being said, there are ways to do it: you certainly don’t have to model a whole city, just the place where the train runs. The train’s proximity to Route 66 is a different story entirely. It could be done as a series of shadow boxes: one box in a Chicago yard, one box in St. Louis with some switching, etcetera, until one reached a Los Angeles terminal yard. Each scene is physically separate, eliminating the need to model the intervening space, with backgrounds to portray each scene.
I’d recommend getting a book on the AT&SF and comparing their system map with this:
Joplin, MO does sound like an interesting place: an interchange between the Frisco and the KCS, two wyes, industries, and even a spot where it looks like one railroad passes over another. Plus it’s not a really big city, probably a good spot for some photogenic modeling. You are correct, it’s an awfully big project for a first layout–but starting with a small layout based in Joplin and building (and motoring) east and west from there might be a good first s
On the Topozone map - I don’t know how old it is - I also see tracks labelled from the MKT (Missouri-Kansas-Texas, aka the “Katy”) and from the Missouri Pacific (aka MoPac). Looks like an interesting place to model.
