I’m not sure if there is a special place around here to link neat videos, but I just came across this and though it was impressive - wanted to share:
https://www.youtube.com/watch?v=zPJgrd43OiA
Pauley
Pauley
That video shows speed but this one shows power! Thank goodness for AC traction motors! This is my favorite RR video.
Reminds me of working the 3rd trick Operators position at North Vernon, IN. B&O trains had to make at Statutory Stop for a NYC branch that crossed at grade. Eastbound was slightly down grade.
The Operator’s job included handing up Train Orders. Handing up to the Eastbound’s head end was no problem as the engines would pass the station at about 10 MPH - with all the engines in the 8th notch. The trick was to locate the markers on the caboose - as Train Orders also needed to be handed up to the Conductor and the rear end crew. By the time the caboose of a Trailer Jet was pounding over the diamond of the crossing and approaching the station it was moving at 50 MPH or thereabouts. The dust being created by the cars pounding over the diamond made it even more difficult in trying to see the markers and return to a position to effect the handing up of the Train Orders.
A time long gone.
View is from the NYC Southbound. Notice that the diamonds are now ‘jump frogs’ for the former NYC - former B&O is all rail and thus doesn’t experience the pounding that existed in 1966.
Too bad such a train ever has to stop between origin and destination. So much energy needed to overcome inertia at rest.
It’s a bunch of empty hoppers. Not really that much trouble to get them moving.
Just an odd thing to lament, IMO.
Amazing what you can do without throttle restrictions. The GEVO engine does produce a satisfying smooth chug, and doesn’t rattle and clank as badly as an FDL.
I’ve always liked this clip, a demonstration of both the superior adhesion of AC units and the abuse that traction motors must endure.
Without comments I find it difficult to understand why the train came to a stop in the first place. Train appeared to have good pace as the head end power passed the camera and it maintained good pace as the head end power went out of sight. Then the rear end power comes into view and the train stops. Was there engine failure on the head end? Was there engine failure on the rear end power? Once the train got restarted, after the low, low, low speed struggle and working of the wheel slip control it appeared to move away at a pretty good pace.
Trains stop for many reasons. Why you find it difficult to understand that a train came to a stop is puzzling.
Dispatchers normally try to not stop a train on a steep grade. Balt was a dispatcher. He was just wondering why the train had to stop.
Trains stop for reasons! I’d just like to know what the reason was that this train stopped on a grade as the video does not make the reason obvious.
If the reason for stopping is not obvious, or stated by an employee at the scene, the only way to anwer the question is if someone involved with making the video called the railroad company and inquired. Stopping without an explanation is puzzling. Wondering why a train stopped for no apparent reason is not puzzling.
I believe that is on the Braganza Ghat line, with a ruling grade of about 2.7% and heavy iron-ore trains. Getting stopped there with the train wrapped around those curves would be no fun.
As s note, there is a special arrangement restricting downhill operation to 30 km/h, below the fade point of the brakeshoes:
I kind of like these Russian freight trains. They seem to have a very serious demeanor. It would be interesting to tour through those locomotives. I understand they use Fairbanks Morse O.P. engines or ones built to that pattern.
This video may be started at time 2:00 to get to the point. It seems like the photographer may have made prior arrangements with the crew to stop on the grade and then restart to demonstrate coming back under load. The video has good audio. Turn it up.
Honorary steam engines.
My railroad knowledge is less than this one sentence.
How does a “jump frog” work? I don’t get the rail setup for crossing trains in this photo.
Frogs are designed for one side to have high speed ‘all rail’ through the crossing. The low speed side ‘jumps’ the high speed rails.
http://industrialscenery.blogspot.com/2015/03/high-speedlow-speed-diamond.html
I found it unusual that a few of the blue cars near the end of the train had their company name written in English “Trans Oil Group of Companies”.
The diamonds at Deshler are now “flange bearing, both directions.” There is no pounding, and trains can move in either direction at speed (35 MPH, I believe). While one can hear some pounding going on, it’s not the diamonds. Instead it’s the circuit isolation joints on each side of the diamond. All you can hear of cars going over the diamond itself is a soft whirr.
The diamonds at Durand, MI, are as Balt describes, with the double track CN Flint sub getting the smooth sailing.
As to the Russian engines.
No EPA.
Definatly not Tier 4
Thanks! I’ve never heard of or seen that before.
