Is there anyway I can add any in cab radio noises for a locomotive on TRS2006?
, HF1001
, HF1001
Yeah just pick a scanner thing on here to listen to and have it run in the back round
With a great deal of effort, we as Trainz Enthusiasts have Radio Chatter, yes actual railroad radio chatter .
These use a revised “Play A Sound File” Driver Command by pitkin. Thanks pitkin for your hard work on the gs files.
The file names are:
BNSF / UP Radio Chatter: consists of 13 files each approx. 3 min long
Download is 6.06mb (small with as many wav files)
Three locations were recorded: Nebraska (UP), Washington (BNSF), and Denver Colorado (UP and BNSF) Radio Signals
CSX / NS Radio Chatter: consists of 14 files each approx. 3 min long
Download is 5.53mb (small with as many wav files)
Three locations were recorded: Central Ohio (CSX and NS - my home area as well), Harrisburg Pennsylvania (NS), and Decatur Alabama (CSX and NS) Radio Signals.
Instructions on How To Use this new Driver Command Per Request:
When creating a New Session (Trusted and Tested):
A) Edit Driver Commands
B) Check either BNSF / UP Radio Chatter or CSX / NS Radio Chatter
C) Edit Driver Set-Up
D) Select “Play Radio Chatter - submenu file ???” and you should see the following driver command icon
When making them available in an existing session ( intermintent functionality )
C) In Driver Mode or Surveyor (Editing Driver Set-Up)
Se
