I’ve been converting my rolling stock to body-mounted Kadee Gauge #1 couplers. I’m also repainting and weathering the cars as I go. Here are the first three – two gondolas and a boxcar… One of the gondolas came with my Buddy L set, the other is from a Bachmann Big Hauler set. I painted them to look like exposed wood and iron. I was thinking of finishing them off with a “peeling paint” effect but they look so good that I may just leave them as “unpainted” stock:
Next is an Aristocraft “Delton Classics” boxcar. I won this in the raffle at our club meeting in October, and I love it. It’s a very nice model with great detail. I only partially painted it – first I sanded down the D&RGW logos, the sprayed the sanded areas with a bit of red primer. It’s a close match for the car’s original color. Doing it this way allowed me to keep the reporting marks and other small lettering. The catwalk was repainted to look like old wood. I then used a series of very thin washes to dirty the car up a little and bring out the detail. Some washes were acyrlics and water, and some used alcohol instead of water. I accidentally discovered an interesting technique when I applied some alcohol that I’d been using to clean brushes. It also contained residue from Sculpy “Premo”. It seemed to react slightly with the plastic and created a faded, water stained effect. A light application was used along the bottom edge on the sides, and a heavier application was used on the roof:
I still have to paint the trucks and replace the plastic wheels with metal. We also have a new RS-3 diesel locomotive from Aristocraft. It was a Christmas gift from my wife’s brother Matt.
THANKS FOR THE PICTURES, THEY WERE GREAT. I ESPECIALLY LIKE THE WAY YOU WEATHERED THE CARS!!
JOHN
Thanks! When I painted the gondolas, I first sprayed them with gray primer, then misted on a little Rustoleum Painter’s Touch Satin “nutmeg” and “espresso”. Then I went over the wood areas with thin washes of Apple Barrel flat acrylics, starting with mixes of “country tan” and “nutmeg brown”, then adding more black to the later washes. For the iron, I used a straight mix of Apple Barrel flat black, “chocolate bar”, and just a little “nutmeg brown”.
I love looking at the work you have done. You put a lot of heart into it thats for sure. Seeing your elevations and all I’m tempted to turn my phony snow shed wanna be tunnel into a real mountain with a tunnel.
